Golf 5 2.0 TDI Engine Oil: 170HP Performance
quickmo
Post13-03-2018, 11:43    Subject: Golf 5 2.0 TDI Engine Oil: 170HP Performance Quote
I own a Volkswagen Golf 5 2.0 TDI with 170 horsepower and a particulate filter.
Currently, I am using 5W30 LL oil and would like to switch to a different type of oil.
Unfortunately, I can't find any other motor oil online that is suitable for my car; it always seems to be only 5W30 LL.
Do you know if I can use a 5W40 oil with a service interval of 15,000 km or 1 year?
Translated on 07-08-2026, 2:59.
Post13-03-2018, 12:11    Subject: Golf 5 2.0 TDI Engine Oil: 170HP Performance Quote
The engine itself would also work with a 5W-40 oil that meets the 505.01 standard, but it wouldn't be optimal for the DPF (Diesel Particulate Filter). The manufacturer clearly specifies the 507.00 standard, which only allows for a 5W-30 oil.
Translated on 07-08-2026, 3:00.
quickmo
Post13-03-2018, 12:14    Subject: Golf 5 2.0 TDI Engine Oil: 170HP Performance Quote
TDI-GTI-4-Motion wrote:
The engine itself would also work with a 5W-40 oil that meets the 505.01 standard, but it would be suboptimal for the DPF. The manufacturer clearly requires the 507.00 specification, which is only met by a 5W-30 oil.
So, should I stick with 5W30 then? Which one is the best for that?
Would you drive it every 15,000 km / 1 year?
Translated on 07-08-2026, 3:01.
Post13-03-2018, 12:17    Subject: Golf 5 2.0 TDI Engine Oil: 170HP Performance Quote
For the sake of maximizing lifespan, a clear "yes" to using a DPF (Diesel Particulate Filter).
We could debate this for days; one person prefers this, another prefers that. Ask 10 people and you'll get 10 different opinions. Just use a brand-name oil and be done with it; don't always overthink things. We're talking about a mass-produced engine here. icon_wink.gif
Translated on 07-08-2026, 3:02.
Post14-03-2018, 11:08    Subject: Golf 5 2.0 TDI Engine Oil: 170HP Performance Quote
In addition to that:
For some time now, there have also been many 0W-30 oils that meet the required VW standard.
Current list of approved items:
https://erwin.volkswagen.de/erwin/downloadStaticFile/volkswagen/files/oil/step_50400_50700.pdf
Translated on 07-08-2026, 3:03.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post14-03-2018, 21:47    Subject: Golf 5 2.0 TDI Engine Oil: Best Choices & Reviews Quote
Do you know if I can use a 5W40 oil with a 15,000 km / 1 year interval?
Yes, if you change the oil annually with a fixed interval, then 5W40 can be used if:
VW Standard 505.01 <- Unit Injector.
and approved for ACEA C3 <- low SAPS/DPF.
z. B:
- Total Quartz Ineo MC3 5W-40 (meets specifications 502.00 and 505.01)
- Castrol 5W-40 Edge Titanium FST (DPF VW 502.00 505.01)
- Castrol Magnatec Diesel 5W-40 DPF (meets VW specifications 502.00/505.00/505.01)
- ARAL HighTronic 5W-40 (ACEA C3, MB 229.31, VW 502 00, 505 01)
- FUCHS TITAN GT1 5W-40 (ACEA C3, MB 229.31, VW 50200, 50501)
- Valvoline 5W-40 Synpower XTreme MST C3 (specifications 50200, 50501)
- Liqui Moly TopTec 4100 5W40 C3 (VW 50500/50200/50501)
- Meguin Megol LowEmission C3 5W40, approved for MB 229.31 and VW PD 505.01.
Therefore, there are many 5W40 oils that have the approval for use with particulate filter systems (DPF).
Regarding the 0w30 oil, it might be approved, but I'm always very cautious about using it because 0w30 has a reduced HTHS (High-Temperature High-Shear) value to save fuel, which may not be ideal for the high forces generated by a PPD (Particulate Matter Diesel) engine.
However, everyone must decide this for themselves; the small list is only meant to show that there are indeed products available that meet your "requirements."
Regards, Mpire.
Translated on 07-08-2026, 3:06.
quickmo
Post14-03-2018, 21:50    Subject: Golf 5 2.0 TDI Engine Oil: 170HP Performance Quote
Thank you for all the answers; I think I will then use the Liqui Moly TopTec 4100 5W40 C3. icon_smile_thumb_up.gif
Translated on 07-08-2026, 3:10.
Post14-03-2018, 22:15    Subject: Golf 5 2.0 TDI Engine Oil: Best Choices & Reviews Quote
Mpire wrote:
Regarding the 0w30 oil, it might be approved, but I'm always very cautious about using it because 0W30 has a reduced HTHS (High-Temperature High-Shear) value to save fuel, which may not be ideal for the high forces in a PPD (Pump Pressure Direct Injection) engine.
No, not that 0W-30 oil after 50,000 kilometers. It also has an HTHS value greater than 3.5.
You probably mean the old 0W-30 oil that met the VW 506 01 specification. It indeed had an HTHS viscosity of 2.9.
Translated on 07-08-2026, 3:11.
No new posts Debris and fragments in engine oil bind General Tips
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Error: Volkswagen Golf 6 2.0 TDI Fix Diesel Engine Technology
No new posts Golf 7 2.0 TDI - Hesitation/Misfire at Partial Load Diesel Engine Technology
No new posts Golf 2.0 TDI 110hp - boost pressure too high at partial load Diesel Engine Technology
No new posts Timing Belt Audi A3 8V1 & Golf 7 2.0 TDI Diesel Engine Technology
