VCDS: Grayed-out Measurement Values Explained
bosst
Post22-02-2018, 19:54    Subject: VCDS: Grayed-out Measurement Values Explained Quote
Hello, I've had my Hex-V2 for a few days now. Today, I wanted to test my KPower software, but my data blocks are grayed out in the MSG, which means I can't click on them.
"And if I create a log using the 'Advanced Measurement Data' function, specifically for speed and RPM, KPower doesn't recognize the log."
The vehicle is a 2014 Skoda Octavia RS 2.0 TDI.
Translated on 28-09-2026, 18:38.
Post23-02-2018, 9:00    Subject: VCDS: Grayed-out Measurement Values Explained Quote
It is perfectly normal for newer engine control units to have the "Measured Values" button disabled in VCDS, because the corresponding diagnostic function is simply not supported.
From your engine control unit, just to make sure it's perfectly clear.
Therefore, click on "advanced measurements," then "group measurements" for better time resolution, and then select "RPM" and "speed" to log.
Have you read the instructions for KPower?
Please upload your log file here as an attachment. By the way, KOBD2Check can also generate the logs required for KPower.
Translated on 28-09-2026, 18:39.
bosst
Post23-02-2018, 21:21    Subject: VCDS: Grayed-out Measurement Values Explained Quote
I have read and understood the instructions.
Okay, that makes sense. I just wasn't sure about the grouping part.
I've attached the log file. As I mentioned, when I try to import it like this, it doesn't find the "Time" column!
Skoda Octavia RS 2.0 TDI.CSV
 File name:  Skoda Octavia RS 2.0 TDI.CSV
 File size:  9.36 KB
 Downloaded:  498 times
Translated on 28-09-2026, 18:40.
Post23-02-2018, 23:35    Subject: VCDS: Grayed-out Measurement Values Explained Quote
VCDS changes the column labels just like I change my underwear. In your log, you completely omitted the unit for time (seconds) and instead inserted a useless space before "km/h". When you connect a different car, the log might look different again. icon_idea.gif
At some point, I got tired of dealing with that, so I programmed my own data acquisition system (KOBD2Check), which eliminates all that unnecessary fiddling.
https://shop.dieselschrauber.org/en/obd2-diagnose-kit-p-321.php
It works across different manufacturers via OBD2, with a reasonable sampling rate for the measured values, and without pseudo-random column names in the log. It offers better temporal resolution and therefore a more accurate performance curve. In short: no headaches and no fiddling. icon_wink.gif
For the "Skoda Octavia RS Combi 2.0 TDI (184 hp)", I found a curb weight of 1487 kg online and simply added 100 kg for the driver and fuel. Of course, the actual weight should be entered in KPower during the measurement.
Result see attached files...
 Verwendete KPower Einstellungen
 File size:  49.5 KB
 Viewed:  1402 times
 KPower Leistungskurve mit VCDS Messwerten
 File size:  141.71 KB
 Viewed:  480 times
Skoda-Octavia-RS-2.0TDI.kpm
 KPower-Datei
KPower-Datei
 File name:  Skoda-Octavia-RS-2.0TDI.kpm
 File size:  1.45 KB
 Downloaded:  351 times
Translated on 28-09-2026, 18:42.
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 17.8.0: Advanced Measurement Data On-Board Diagnostics (OBD)
No new posts Measurement Blocks: Grey Color Options On-Board Diagnostics (OBD)
No new posts Audi A4: White/Gray Smoke - What Causes It? Diesel Engine Technology
No new posts Grey White Exhaust Smoke: Causes & Fixes Diesel Engine Technology
