Passat 3C: Battery disconnected - now errors
Post15-09-2007, 16:57    Subject: Passat 3C: Battery disconnected - now errors Quote
Hi.
I disconnected the battery on the 3C, and now I have ABS errors in the 03 module and a lane assist error in the 44 module.
I had to type this out because I don't have internet access here.
ABS:
Part number SW: 3C0 614 109 A Hardware number: 3C0 614 109 A
Part number: ESP 440 C4 H018 0001
Encoding: 0013626
00778 - Steering angle sensor (G85)
005 - No or incorrect initial setup/adjustment.
Steering assistance:
Part number: 1K1 909 144 L
Component: EPS_ZFLS, Class 126, H07, 1806.
000 - -
What should I do?
Probably a default setting, but why does this component forget the default setting when the battery is disconnected?
Okay, I'll look for the default settings... if anyone has them readily available, please pass them over.
Thank you.
Martin.
Post15-09-2007, 19:09    Subject: Passat 3C: Battery disconnected - now errors Quote
Funny.
I had to go back again... and after 100 meters, the warning lights went out.
"The error codes have also disappeared."
But how can the G85 self-calibrate, since it doesn't actually know what "straight" is...
Ross-Tech-Support
Post15-09-2007, 19:19    Subject: Re: Passat 3C: Battery disconnected - now errors Quote
dieselmartin wrote:
Probably a basic setting, but why does this part forget the basic setting when the battery is disconnected?
Protection function! Be glad you don't have a Bosch 5.7 ABS system, because it not only forgets the basic settings, but also the coding.
dieselmartin wrote:
Let me look for the default settings... if anyone has them readily available, please bring them over.
As usual...
dieselmartin wrote:
http://de.openobd.org/vw/passat_3c.htm#03But how can the G85 self-calibrate, since it doesn't actually know what "straight" is...?http://wiki.ross-tech.com/index.php/VW_Passat_%283C%29_Brake_Electronics
He probably already knows that, although with enough driving, that knowledge might fade, and in your case, the data wasn't completely lost.
Held467
Post15-09-2007, 20:44    Subject: Re: Passat 3C: Battery disconnected - now errors Quote
Hello.
Is that normal for newer cars, or is it an exception?
Sincerely, Sure, here is the translation of the text from German to English:
"Dirk"
vagtuning
Post15-09-2007, 23:38    Subject: Passat 3C: Battery disconnected - now errors Quote
No, it's more the rule than the exception...
Do Audis behave the same way? If you disconnect the battery, do the error lights sometimes come on until you drive a bit and it starts providing values again?
'He received the steering angle sensor and the other one.'
Post16-09-2007, 9:09    Subject: Passat 3C: Battery disconnected - now errors Quote
Here's what I did:
"Nothing - and that scares me almost more than the fact that errors occurred."
I had him standing in the driveway.
Manually adjust the footwell lights.
To connect the power cable to the onboard network control unit, I disconnected the battery for about 10 minutes.
Battery connected, VAGCOM connected, footwell lights coded, and the other control units have errors icon_sad.gif.
Then I really had to go, so I'm leaving now, because the traffic lights are only yellow.
"Reverse 10 meters, turn 90 degrees left onto the street. Then proceed straight, and after approximately 50-100 meters, both warning lights should turn off. Restarting the engine after driving 7 kilometers also does not bring back any warning lights." Back to the source of the errors, and after reading the code... the errors disappeared on their own.
Okay, it's better this way than another way...
Thank you for the help... I was quite nervous because of my poorly functioning internet and the stress I was experiencing with T-Mobile's UMTS service.
tempO144
Post24-04-2018, 9:21    Subject: Also, here's the translation: Had the same problem with the steering angle sensor Quote
I had the same problem. Resetting to the default settings didn't help, and the error light remained on. The instructions from the Ross-Tech Wiki were helpful.
(Point "Special Procedures").
I turned sharply to the left, waited a bit, then two beeps sounded, and I repeated the process to the right => the warning light went out.
I'm guessing that the torque sensors and/or the steering end-stop positions need to be calibrated. It's fully electric, and it would likely continue to "push" even when at the end stop.
Hopefully, this might help someone avoid searching for something they lost two days after the fact.http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist{MARKER}
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Drain: Audi A2 8Z0 MJ 2002 Doc Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Airbag Control Module Replacement: Error 00589 On-Board Diagnostics (OBD)
No new posts Errors cleared after disconnecting the battery On-Board Diagnostics (OBD)
No new posts Defective second battery in Passat 3C5 (AGM)? Electrical Systems, Vehicle Electronics, Multimedia
No new posts AGR disconnected Diesel Engine Technology
