Passat CBAB Error: High-Pressure Pump Replacement?
durnesss
Post18-03-2018, 13:44    Subject: Passat CBAB Error: High-Pressure Pump Replacement? Quote
Hi everyone,
Our piece of junk software is acting up again.
It received a new high-pressure pump 18 months ago and is now sporadically throwing errors.
The numbers 004197 and 000136 bother me the most.
I attribute the majority of the issue to undervoltage caused by winter conditions and operation in a short-haul mode.
Where do I start?
passat0318.txt
 File name:  passat0318.txt
 File size:  16.44 KB
 Downloaded:  666 times
Translated on 18-10-2026, 21:11.
Post18-03-2018, 14:27    Subject: Passat CBAB Error: High-Pressure Pump Replacement? Quote
I would like to use a
high-pressure generator B10AE 14 [008] - Short circuit to ground/ground fault.
Fuel system (bank 1) rail/system pressure too high
starting.
Since the error scan shows a high-pressure reading in addition to the pressure regulation difference, you can likely be quite confident about the high-pressure pump. If the high-pressure pump is worn out, it won't be able to build up the necessary pressure in the fuel rail.
Therefore, I suspect that the fuel pressure regulator problems are caused by the fuel pressure sender and/or the pressure control valve. Also, carefully check their associated wiring and connectors.
Translated on 18-10-2026, 21:12.
durnesss
Post18-03-2018, 15:03    Subject: Passat CBAB Error: High-Pressure Pump Replacement? Quote
The climate story is ultimately secondary.
Regarding the diesel pressure, I'm suspecting the pressure sensor.
Is the M18x1.5 pressure sensor, part number #03L 906 054A, the correct one?
Translated on 18-10-2026, 21:14.
Post18-03-2018, 15:19    Subject: Passat CBAB Error: High-Pressure Pump Replacement? Quote
Is the M18x1.5 pressure sensor #03L 906 054A the correct one?
I have no idea; the VAG part number should also be found on the sensor itself.
Climate stuff: I scrolled too far down while trying to find the text to copy, so it was edited. Nevertheless, a faulty high-pressure pump is an unrealistic cause for excessively high rail pressure.
What exactly was the cause of the failure in the last high-pressure pump, and was the injection system cleaned or completely replaced (due to debris)?
Translated on 18-10-2026, 21:15.
durnesss
Post18-03-2018, 18:25    Subject: Passat CBAB Error: High-Pressure Pump Replacement? Quote
It was cleaned, but I didn't do it myself; I took it to the dealer.
It was only idling. Apparently, it was completely worn out with a near-zero boost pressure.
Let's see what the new sensor does.
Translated on 18-10-2026, 21:16.
No new posts Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts VR6 error code P1340 despite new timing chain Gasoline Engine Technology
No new posts TDI PD Element Leaks: Fix with New Seals & Head Gasket? Diesel Engine Technology
No new posts V6 Engine Won't Start: Fuel Pump Replacement Failed? Diesel Engine Technology
No new posts The left low beam headlight is not working despite a new ... Electrical Systems, Vehicle Electronics, Multimedia
