vag-driver Profi-Schrauber
02-04-2018, 9:18 Subject: Gasoline Refill: 2.2 Liters Added |
It happened to me for the first time yesterday.
I accidentally put 2.2 liters of E10 gasoline into my car. Since the tank was empty, I then filled it with 66 liters of diesel. This is about my Sharan CFGB.
My mind tells me that everything will be alright. But somehow, I have a bad feeling about it.
I hope you can calm me down.
Andreas
Translated on 21-10-2026, 14:35.
Gremlin Schrauber
Joined: 08/18/2005 Posts: 396 Karma: +92 / -0 Location: Grainet 2000 Audi A4 Avant  Premium Support
02-04-2018, 18:49 Subject: Gasoline Refill: 2.2 Liters Added |
Hello;
I would argue that this can be neglected in that relationship.
Previously, to make diesel more resistant to freezing, people would add a few liters of gasoline; and this made a significant difference (I believe I read that it could be up to 10%, unfortunately, I don't know the source).
If you are concerned about the lubrication properties, add just a tiny bit, like the tip of a finger, of 2T oil.
Translated on 21-10-2026, 14:36.
Profile PM Garage |
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2557 Karma: +591 / -0 Location: bei Zwickau
02-04-2018, 21:21 Subject: Gasoline Refill: 2.2 Liters Added |
Hi!
In the past, when temperatures were extremely cold, it was common to mix up to 25 or 30% gasoline with diesel fuel in trucks.
"Here, at work, if the temperature is forecast to drop below -20°C, we also get a gasoline allowance. It's 5 liters of gasoline for every approximately 130 liters of diesel."
Translated on 21-10-2026, 14:37.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
03-04-2018, 9:06 Subject: Gasoline Refill: 2.2 Liters Added |
Gremlin wrote: | Hello;
Previously, to make diesel more resistant to freezing, people would add a few liters of gasoline | .
However, this was long before the use of common rail high-pressure pumps with lubrication-sensitive components. Today, manufacturers explicitly warn against even the smallest amounts of gasoline.
@ vag-driver :
I would definitely use 2T oil in this case. Make sure to avoid synthetic oils, and if possible, also avoid oils with colorants. For example, Alpine 2T oil is mineral-based and uncolored.
Translated on 21-10-2026, 14:38.
Profile PM Garage |
03-04-2018, 10:17 Subject: Gasoline Refill: 2.2 Liters Added |
Roger wrote: |
@vag-driver :
I would definitely do what's suggested about the 2T oil. When doing so, make sure not to use a synthetic one, and avoid dyes if possible. For example, Alpine 2T oil is mineral-based and uncolored. |
How much should I mix in? Is it available for purchase anywhere in the Rhine-Main area?
Andreas
Translated on 21-10-2026, 14:39.
03-04-2018, 10:27 Subject: Gasoline Refill: 2.2 Liters Added |
I would already add 0.2 liters in the current situation. Mixing it without subsequent refueling is a problem, perhaps a skillful slalom  might help.
I only saw it online; I didn't use any myself during my time with diesel vehicles. However, what I've seen in common stores is usually red-colored and fully synthetic.
Translated on 21-10-2026, 14:40.
Profile PM Garage |
03-04-2018, 10:34 Subject: Gasoline Refill: 2.2 Liters Added |
Roger wrote: | | What I've seen in the common markets was mostly dyed red and fully synthetic. |
I am not familiar with any other 2-stroke oils that are currently available in stores.
Andreas
Translated on 21-10-2026, 14:41.
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
dieselschrauber likes this. |
04-04-2018, 8:46 Subject: Gasoline Refill: 2.2 Liters Added |
If anyone is concerned about the coloring of the two-stroke oil, there is no need to worry. The visible color in the fuel tank will disappear due to the additives used. "Solvent Yellow" is something different; it's the dye used to mark heating oil.
Furthermore, the mixture can be diluted by repeatedly topping up the tank with regular diesel fuel during the process. Therefore, refuel as soon as there is room for another 10 liters.
04-04-2018, 8:55 Subject: Gasoline Refill: 2.2 Liters Added |
I wasn't really thinking about using a marker for that. Also, the dyes don't completely disappear without leaving any residue. Although... if it's only used once...
Translated on 21-10-2026, 14:42.
Profile PM Garage |
04-04-2018, 14:10 Subject: Gasoline Refill: 2.2 Liters Added |
Hutfahrer wrote: |
Furthermore, the mixture can be further diluted if, during the process, the tank filled with the adulterated fuel is repeatedly refilled with normal diesel fuel. Therefore, refuel as soon as another 10 liters can fit in. |
That's my plan. So far, thankfully, I haven't noticed any damage. Also, I can't find anything negative about the driving experience (acceleration, smoothness, engine noise, fuel consumption). I've driven about 220 km since then.
The gasoline content is 3.14%, assuming a 70-liter tank.
Andreas
Translated on 21-10-2026, 14:43.
Gremlin Schrauber
04-04-2018, 19:17 Subject: Gasoline Refill: 2.2 Liters Added |
Roger wrote: | | I didn't have the marker in mind as much, and the dyes also don't disappear completely without leaving any residue. Although... with a single application... |
Right now; it's not forever; but (hopefully) just a one-time thing.
I mean, the engine oil fumes that are drawn in through the ventilation system probably won't burn completely...
Translated on 21-10-2026, 14:44.
Profile PM Garage |
12-04-2018, 20:33 Subject: Gasoline Refill: 2.2 Liters Added |
I just filled up the tank for the first time. I was able to add 40 liters. The engine is still running normally. I hope it stays that way.
Andreas
Translated on 21-10-2026, 14:45.
12-04-2018, 20:49 Subject: Gasoline Refill: 2.2 Liters Added |
I hope so too.
20-04-2018, 12:54 Subject: Gasoline Refill: 2.2 Liters Added |
Yesterday, I filled the tank with 36 liters. It was almost empty, and even though I intended to refill it regularly, I had forgotten in the rush.
Fortunately, there have been no incidents so far.
Andreas
