| Motosteuergerät Softwareversions- und Modifikationscheck |
| Sinnvoll brauche ich |
95% |
[ 19 ] |
| Braucht kein Mensch |
5% |
[ 1 ] |
| Total votes : 20 |
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
07-01-2018, 13:15 Subject: Engine Control Unit (ECU) software version and chip tuning check |
Would it be helpful to include a note in the diagnosis indicating that a newer software version exists for the engine control unit, and if so, which one?
At the same time, for vehicles meeting EU5 standards or higher, an integrity check of the engine control unit (ECU) software could be performed to determine whether it is original or has been modified.
How useful do you find this feature?
Translated on 18-07-2026, 3:19.
Profile PM WWW Garage |
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
07-01-2018, 16:10 Subject: Engine Control Unit (ECU) software version and chip tuning check |
Hello.
I would find that very useful.
- I usually have VCDS with me when buying a car or during a test drive.
With this function, one could already infer certain "things" and potentially make a better purchasing decision  .
- When troubleshooting issues on customer vehicles, knowing about undocumented or unauthorized modifications could make it easier to pinpoint the source of certain problems.
- or alternatively, you can inform the customer that a newer software version is available, which the original equipment manufacturer (OEM) intends as a solution to the problem.
Mpire
Translated on 18-07-2026, 3:20.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
07-01-2018, 19:41 Subject: Engine Control Unit (ECU) software version and chip tuning check |
I would also find a reference to a more recent version helpful. You don't necessarily have to rely on the workshop for that information.
Translated on 18-07-2026, 3:21.
Profile PM Garage |
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2557 Karma: +591 / -0 Location: bei Zwickau
07-01-2018, 22:15 Subject: Engine Control Unit (ECU) software version and chip tuning check |
Hi!
If it's possible, it would be a very worthwhile endeavor.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
07-01-2018, 22:17 Subject: Engine Control Unit (ECU) software version and chip tuning check |
I would also think that's great, but on what data basis could it be reliably evaluated?
Pretzelman.
Translated on 18-07-2026, 3:22.
08-01-2018, 9:14 Subject: Engine Control Unit (ECU) software version and chip tuning check |
brezelmann01 wrote: | Hello,
Brezelmann | .
Basic probability and statistics.
It's highly likely that the corresponding tool will read the data through diagnostics, making user manipulation a rather unlikely scenario – almost like finding a "pink elephant." While it might be technically possible, who would do it and why would they bother? It's absolutely manageable.
And a data or software version that doesn't appear anywhere else would be even more suspicious.
Translated on 18-07-2026, 3:23.
18-01-2018, 15:50 Subject: Engine Control Unit (ECU) software version and chip tuning check |
A test version of KOBD2CHECK, which provides information about newer software versions and indicates whether an existing CVN is genuine (i.e., the engine control unit software is original), is complete.
Download: see attached .rar archive. Please note that the trial version only works with the Diesel Mechanic RKS+CAN interface. This is included with the "OBD2 Diagnostic Kit" and the "CAN-USB Interface Kit".
In order to display the information, KOBD2CHECK needs internet access. To start the scan, click the [Scan] button in KOBD2CHECK.
Translated on 18-07-2026, 3:25.
chli1976 Profi-Schrauber
18-01-2018, 16:55 Subject: Engine Control Unit (ECU) software version and chip tuning check |
Is that just an example in the Screenshot?
For this part number, the software version is 4150.
VCDS
Translated on 18-07-2026, 3:26.
chli1976 likes this. |
18-01-2018, 17:44 Subject: Engine Control Unit (ECU) software version and chip tuning check |
chli1976 wrote: | Is that just an example in the Screenshot?
For this part number, the software version is 4150 | .
Of course, it's just an example...
The following software versions are available for product 03G906016ME: 0945, 1141, and 4150.
Translated on 18-07-2026, 3:27.
20-01-2018, 13:16 Subject: Engine Control Unit (ECU) software version and chip tuning check |
KOBD2Check has been further refined and is now ready for production use.
Product in the shop: https://shop.dieselschrauber.org/en/obd2-diagnose-kit-p-321.php
The software package for testing the RKS+CAN CAN bus interface is attached.
| Description: |
Prüfung auf neueren Softwarestand des Motorsteuergeräts.
Sofern vom Motorsteuergerät unterstützt, Prüfung der Steuergerätesoftware auf Modifikation. |
| File size: |
94.18 KB |
| Viewed: |
1312111 times |
| Description: |
| Installationspaket für RKS+CAN (Dieselschrauber/CANHack) CAN-Bus Interface. |
 Download |
| File name: |
RKS+CAN_GER_370-Installer.rar |
| File size: |
7.53 MB |
| Downloaded: |
451 times |
Translated on 18-07-2026, 3:28.
02-02-2018, 18:48 Subject: Engine Control Unit (ECU) software version and chip tuning check |
The calibration ID seems to be outputted in different formats...
I would be grateful if you could provide me with the results of a KOBD2Check scan (see the image "ECU-software-check-KOBD2Check.jpg" above).
User_5841264171
11-04-2018, 22:11 Subject: Engine Control Unit (ECU) software version and chip tuning check |
I'm using Kobd2check v1.70 - SCAN and I want to check if there's a newer software version available for my engine control unit, or whether the current CVN is the original one. However, it always only displays the existing software version and CVN, regardless of which vehicle I scan? And this is happening even though I have an internet connection.
Calibration ID: 03L906018PT 9980
CVN: 3F0B6B78
Greetings.
Translated on 18-07-2026, 3:29.
12-04-2018, 8:44 Subject: Engine Control Unit (ECU) software version and chip tuning check |
Hi.
Quote: | | However, it always only displays the existing software version and CVN, regardless of which vehicle I am examining. |
No, as I interpret the database, the vehicle you mentioned is the only one that you checked.
The database grows as it is used more. However, for your VAG part number of the engine control unit, there was no entry yet for this software version; it will be automatically added when the data is read. The more people scan their cars, the faster the database grows.
9980 should currently be the latest software version for your engine control unit.
If a newer software version or the same version with a different CVN exists in the database, KOBD2Check will display corresponding information to you (an active online connection is required).
Translated on 18-07-2026, 3:31.
