OBD2 Calibration ID for New Audi, Seat, Skoda, VW Cars
Post18-04-2018, 14:54    Subject: OBD2 Calibration ID for New Audi, Seat, Skoda, VW Cars Quote
Calibration ID: 04L056KL3802JEADNOX00907805 0034
CVN: 4DA2FB63B866C2AD
Engine control unit: ECM - Engine Control
I've just noticed that on newer VAG vehicles, the part number of the engine control unit (ECU) is no longer displayed completely, or not at all.
"Previously, the standard information included: part number of the engine control unit (ECU) and software version."
The length of the CVN has also doubled.
What is?
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Translated on 23-08-2026, 3:48.
Post18-04-2018, 15:44    Subject: OBD2 Calibration ID for New Audi, Seat, Skoda, VW Cars Quote
Under which VCDS function can you find it exactly?
During a scan of the 2018 Volkswagen Golf, everything appears to be as it should be.
Address 01: Engine Control Module (2D2D2-DDYA) Label file: None.
Part number SW: 04L 906 056 GT, Hardware part number: 04L 907 445 E.
Part: R4 1.6L TDI H01 3757
Revision: 22005001
Encoding: 01114012441419092000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI03004L906056GT 004004
ROD: EV_ECM16TDI03004L906056GT_004_VW37.rod
VCID: 050BE6E1843D0D6EB9-8050
Translated on 23-08-2026, 3:51.
Post18-04-2018, 18:25    Subject: OBD2 Calibration ID for New Audi, Seat, Skoda, VW Cars Quote
Hello Herbert,
The data was read out using KOBD2Check, but the OBD2 mode of VCDS essentially says the same thing.
The calibration ID is initially not very relevant to VCDS.
Translated on 23-08-2026, 3:53.
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Diagnosis: Seat, VW, Audi, Skoda Diesel Engine Technology
No new posts OBD2 Connector Audi A3, 2001 Diesel Engine Technology
No new posts OBD2 Adapter: MFA via OBD2 Diesel Engine Technology
No new posts Automotive Network Security Standards: Questions On-Board Diagnostics (OBD)
