Chris_43
19-04-2018, 10:28 Subject: ...and another P0299 |
A wonderful good morning to all the professionals here!
I would really appreciate your help again.
For a few days now, my Tiguan (2.0L TDI 140hp, built in 09) has been malfunctioning.
The orange warning light is flashing, the engine control light is on.
Loss from the bottom up.
Error code: P0299, Turbocharger Boost Control, Control Difference Below Specified Limit.
I was able to delete errors, but they still remain.
Still noticeable intermittent power loss from below.
(Sometimes he still pulls out, but in my opinion, the cases where he does pull out are becoming less frequent.)
Now I've read a lot about the VTG mechanism, VTG clamps, faulty pressure cans, etc. here...
So far, I understand everything.
But: Upon closer inspection, I have discovered that the axle in the AGR cooler is broken (where the pressure cap of the AGR cooler sits, and the lever inside operates), right into the cooler.
That means that there, in the hole, exhaust fumes will naturally escape.
Now, my question:
Is it possible that I could "lose" the boost pressure there?
I think that if I release the gas from the bottom, and the engine runs under load, then the AGR valve should be closed, and therefore the "pressure line from the turbo" should be sealed off towards the AGR cooler?
Or am I misunderstanding?
(e.g., because the AGR valve is actually (somewhat) open during acceleration?)
For your expert assistance, I would be very grateful.
Best regards to the community
Chris Tiguan BJ 2009 2.0L TDI 140PS
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
19-04-2018, 13:34 Subject: ...and another P0299 |
Quote: | However: Upon closer inspection, I have found that the axle in the AGR cooler is broken (where the pressure cap of the AGR cooler sits, and the valve inside operates), going right into the cooler.
That means that there, at the hole, exhaust fumes will naturally escape.
Now my question:
Is it possible that I could "lose" the boost pressure there? |
The turbocharger is driven by the exhaust gases of the engine. If these gases simply escape, the shaft of the turbocharger has no drive.
Okay, close the exhaust leak.
Another cause for low boost pressure is leaks in the intake air system (for more information on "intake air system", please use the search function), or inadequate control of the VTG, for example, due to vacuum problems or a faulty adjustable valve, etc.
More information with Autoscan.
Best regards, Rainer
Profile PM WWW Garage |
Chris_43
28-04-2018, 10:53 Subject: Hello, Here's the car scan. |
Thank you in advance
