Brake Electronics: Incorrect or No Calibration
Jahresprogramm
Karma: +0 / -1   Thank you, like it!
2012 Volkswagen Golf
Post17-11-2019, 18:21    Subject: Brake Electronics: Incorrect or No Calibration Quote
After accessing the basic settings in the brake electronics and selecting "Hydraulic unit calibration of the inlet valves," the following error code was stored in the control unit:
"no or incorrect initial setup/adaptation"
Out of desperation... and to top it all off, I accidentally activated the system function test.
Currently, this is also being stored as an error code.
Could someone please help me complete the adaptation and system testing process?
Thank you very much, and best regards.
Alex.
Log-WV2ZZZ2KZCX139676-143700km.txt
 File name:  Log-WV2ZZZ2KZCX139676-143700km.txt
 File size:  10.65 KB
 Downloaded:  465 times
Translated on 29-08-2026, 19:19.
vag-driver
dieselschrauber likes this.
Post18-11-2019, 10:50    Subject: Brake Electronics: No or Incorrect Initial Setup Quote
What's the background here? Was something swapped out? Were there any errors beforehand?
You don't perform a basic alignment just for fun.
Andreas
Translated on 29-08-2026, 19:21.
Jahresprogramm
Post18-11-2019, 18:57    Subject: Brake Electronics: No or Incorrect Initial Settings Quote
vag-driver wrote:
What is the background? Was something exchanged? Were there any errors beforehand?
The photo was taken out of stupidity or curiosity. There's no other reason behind it.
Alex.
Translated on 29-08-2026, 19:22.
Jahresprogramm
Post22-11-2019, 6:25    Subject: Brake Electronics: Incorrect or No Calibration Quote
Is there no way to relearn this? What would you recommend: going to a dealership or an independent workshop? Does the independent workshop have the capability to reset this?
Sure, here's the translation:
"Thank you in advance!"
Alex.
Translated on 29-08-2026, 19:23.
Karma: +1344 / -0   Thank you, like it!
dieselschrauber and Jahresprogramm likes this.
Post23-11-2019, 11:37    Subject: Brake Electronics: Incorrect or No Calibration Quote
Let's start with the system function test.
If it cannot be deactivated using VCDS, then you must perform the procedure.
Step-by-step:
Is the ABS warning light on?
2) And here we go again:
Translated on 29-08-2026, 19:24.
Post25-11-2019, 0:44    Subject: Brake Electronics: Incorrect or No Calibration Quote
Will it work?
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Parking Heater: Incorrect/Missing Initial Settings On-Board Diagnostics (OBD)
No new posts Audi A2 Throttle Body, cannot set default settings Gasoline Engine Technology
No new posts Error memory empty or no communication On-Board Diagnostics (OBD)
No new posts Steuergerät für Bremsenelektronik codieren- Hilfe benö... On-Board Diagnostics (OBD)
