Access permission, radial dampening
Undergrkg87
Post11-05-2018, 17:57    Subject: Access permission, radial dampening Quote
Hello!
I want to adjust the vehicle's ride height after lowering it and need the login code for the suspension system to do so.
Does anyone have this? And...
Have a great weekend!!!
Scan-WAUZZZ8V0F1023411-20180511-1719-43504km.txt
 File name:  Scan-WAUZZZ8V0F1023411-20180511-1719-43504km.txt
 File size:  19.21 KB
 Downloaded:  541 times
Karma: +1362 / -0   Thank you, like it!
Post11-05-2018, 18:33    Subject: Access permission, radial dampening Quote
Sure, I can translate the text from German to English. Please provide the text you would like me to translate.
Detective work is tedious.
Undergrkg87
Post11-05-2018, 18:39    Subject: Access permission, radial dampening Quote
I thought it would be obvious in the car scan icon_lol.gif.
It would be an Audi S3 8V, model year 2014.
Post11-05-2018, 19:28    Subject: Access permission, radial dampening Quote
Much better. If you want something, you should clearly state what it is.
Karma: +808 / -0   Thank you, like it!
Post12-05-2018, 8:06    Subject: Access permission, radial dampening Quote
Hello Undergrkg87,
What function in the VCDS control unit overview corresponds to the wheel damping control unit?
There are several things that, depending on the control unit, could function as a login, and I suspect that simply hovering the mouse cursor over the corresponding input field and waiting didn't work?
Undergrkg87
Post12-05-2018, 14:08    Subject: Access permission, radial dampening Quote
Hello Rainer!
It concerns the function "Wheel damping: Adjust height values for each wheel." Unfortunately, it requires a login after changing the values in the customization channel. icon_cry.gif
Unfortunately, the usual speech bubble and login functionality are not working.
Best regards, Mario.
Post12-05-2018, 17:27    Subject: Access permission, radial dampening Quote
Again, what "login" functionality does the control unit offer?
Undergrkg87
Post14-05-2018, 16:56    Subject: Access permission, radial dampening Quote
Hello Rainer,
I don't quite understand which login function you're referring to.
Are there multiple icon_eek.gif icon_biggrin.gif?
I specifically bought a repair manual for the chassis, hoping to gain access, but did you think icon_rolleyes.gif
Post14-05-2018, 17:18    Subject: Access permission, radial dampening Quote
Please post a Screenshot of the control unit information for the relevant control unit.
Undergrkg87
Post14-05-2018, 19:08    Subject: Access permission, radial dampening Quote
Here is the information about the control units.
Is there a way to access the labels again now?
Thank you very much.
Log-WAUZZZ8V0F1023411.txt
 File name:  Log-WAUZZZ8V0F1023411.txt
 File size:  1.73 KB
 Downloaded:  317 times
Post14-05-2018, 19:16    Subject: Access permission, radial dampening Quote
dieselschrauber wrote:
Please post a Screenshot of the control unit information for the control unit in question.
Best regards, Rainer
Undergrkg87
Post14-05-2018, 19:29    Subject: Access permission, radial dampening Quote
Sure.
 File size:  9.15 MB
 Viewed:  725 times
Post14-05-2018, 20:53    Subject: Access permission, radial dampening Quote
Yes, instead of the "Access Permission - 16" button, there are other options available depending on the specific control unit.
I found something, but I'm not sure if it's a good idea to post it publicly (for safety reasons), because an incorrect attitude can affect driving safety. icon_confused.gif
Therefore, please contact support at ross-tech.com directly in this case and explain what you intend to do.
Sure, you can refer to this topic as well.
Undergrkg87
Post15-05-2018, 16:48    Subject: Access permission, radial dampening Quote
Okay.
Thank you, Rainer, for the information.
I'll write to Ros about it.
Greetings from the Allgäu region.
hadez16
Avatar-hadez16
Post06-06-2018, 10:53    Subject: Access permission, radial dampening Quote
The procedure is not yet possible with VCDS.
Only ODIS.
No new posts ECU Access: BKD Engine Control Unit (EDC16) On-Board Diagnostics (OBD)
No new posts Electrical Access Control: Configuration & Setup On-Board Diagnostics (OBD)
New posts Access Control: Steering for Default Settings On-Board Diagnostics (OBD)
No new posts Access Permission: Function 16 Not Selectable On-Board Diagnostics (OBD)
