I wanted to install my new Blaupunkt radio (previously beta) yesterday, and I noticed that the GALA signal is missing from pin 1. Does anyone know where in the electrical panel you can tap into it?
Furthermore, I am not sure whether my antenna is fed externally (I will probably need to measure it again today...).
Thank you, Werner
Passat Variant, AFN, Year 1998
