EDC-Versions Motor Control Unit
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post06-08-2018, 13:50    Subject: EDC-Versions Motor Control Unit Quote
Hi everyone,
can someone tell me something about the hardware of engine control units within a specific model series?
Specifically, this means:
EDC 15 VM+2.V1
z.B. VW 074 906 018 AJ or Bosch 0281010461
to VW 065 906 018 or Bosch 0281010710
Specifically, I would like to know if the multi-connector for the engine control unit has different versions.
Are the multi-connectors the same within a series, for example, in MSG with EDC 15 VM+2.V1?
Post06-08-2018, 19:50    Subject: EDC-Versions Motor Control Unit Translating...
[Translating...]
die Stecker sind meines Wissens bei dem Steuergerätemodell alle gleich.
Viele GrĂźsse, Rainer
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Doku, n.lÜschb. Fehler im Motorsteuergerät 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Heckklappe - verschiedene Versionen Transmission, Chassis, Body & Interior
No new posts Engine Control Unit 1Z Diesel Engine Technology
No new posts A6 C4 TDI Engine Control Unit On-Board Diagnostics (OBD)
No new posts T5 Motorsteuergerät On-Board Diagnostics (OBD)
