Hill Hold Assist Retrofit for ESP MK60E1
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
NoSleep
Post07-08-2018, 3:48    Subject: Hill Hold Assist Retrofit for ESP MK60E1 Quote
I would like to retrofit the hill-hold assist feature to my Audi TT (8J, manufactured in 2013).
How can I do that?
In this case, VCDS only refers to the SVM and does not offer any coding assistance.
Address 03: Brake Electronics. Label file: DRV\8J0-614-517.clb.
Part number SW: 8J0 910 517 A, HW: 8J0 614 517 G.
Component: ESP MK60E1 0030
Revision: 00H60001
Encoding: 0616343
Operating number: WSC 01236 785 00200
VCID: 2A5F6DCE8542EF12BC-807E
Translated on 16-10-2026, 0:34.
Post07-08-2018, 20:49    Subject: Hill Hold Assist Retrofit for ESP MK60E1 Quote
It is likely that the ESP/ABS system in this case requires different software.
Translated on 16-10-2026, 0:36.
NoSleep
dieselschrauber and Herbert likes this.
Post08-08-2018, 21:12    Subject: Coding: How to Code & Learn Programming Basics Quote
I was eventually able to code and activate the hill-start assist feature.
You need to add the value +2048 to the short code of the control unit (don't forget the leading zero...).
After that, channel 58 will be available for adjustment, and you can activate the hill-start assist.
Source: http://www.digital-kaos.co.uk/forums/showthread.php/524246-MK60-ABS-long-coding-for-members/page73?highlight=abs+coding&styleid=48
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hill Hold Assist Tiguan On-Board Diagnostics (OBD)
No new posts DPF Retrofit for RME Vehicles Diesel Engine Technology
No new posts TDI Catalytic Converter Retrofit by VAG? Diesel Engine Technology
No new posts AHK Retrofit Programming: Guide & Tutorial On-Board Diagnostics (OBD)
