Passat 3 BG 1.6 electric radiator fan
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
dokky
2013 Volkswagen Golf
Post08-08-2018, 6:48    Subject: Passat 3 BG 1.6 electric radiator fan Quote
"On our 3 BG unit, both the secondary air pump and the radiator fan were defective. I measured the system, replaced the fan, but now it runs constantly on level 2, which is quite noisy. I also only measured 14V immediately after turning on the air conditioning."
When the air conditioning is turned on, it should run slowly, just like the first stage of the water temperature sensor.
Since I always have to borrow a workspace and the current temperatures aren't exactly conducive to working on things, should I order and replace the pre-resistor now, or can I measure something from the top to see if there's an attempt to switch to stage 1?
Translated on 09-07-2026, 7:36.
Karma: +643 / -0   Thank you, like it!
Post09-08-2018, 17:13    Subject: Passat 3 BG 1.6 electric radiator fan Quote
Checked the thermostat in the radiator?
Translated on 09-07-2026, 7:37.
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C TDI elektrischer Zuheizer defekt Electrical Systems, Vehicle Electronics, Multimedia
No new posts Polo, Glühkerze 3, elektrischer Fehler, Hilfe! Diesel Engine Technology
No new posts P0672 / P0673 - Electrical circuit fault, glow plugs? Diesel Engine Technology
No new posts Cooling fan BLS is vibrating. Diesel Engine Technology
