chli1976 Profi-Schrauber
06-11-2018, 19:09 Subject: Skoda Octavia BKC: Cold Start Problems |
I'm having a problem with my Skoda Octavia; it won't start when it's warm.
I initially thought it was the usual problem, so I increased the initial fuel enrichment, but unfortunately, that didn't resolve the issue.
I checked the rotation angle, and it's jumping from 0 to 0.5° in the low range, so it's not related to the G40 setting.
Okay, so I disconnected the coolant temperature sensor, but it still doesn't start any better. Then, at the very end, I checked what temperature the control module (ECU) displays when the G62 sensor is disconnected. I always thought it would show negative values, but in this case, it displays 40-44°C when the connector is removed. When I used a 4.7k resistor instead of the sensor, the control module displays 4.5°C, which also seems too high for a 4.7k resistor.
Then I also measured the fuel pressure at the tandem pump. It was 2.7 bar at idle, which should be at least 3.5 bar. However, when I restrict the return flow, the pressure increases to over 10 bar, so the PD-O-rings should be okay.
"When I turn it off and immediately restart it, it starts right away. However, if I wait for 2 minutes, it can take a good 20 seconds before it starts, if it starts at all. You can then see on the pressure gauge that there is initially no pressure, which then slowly increases, and it starts when the pressure reaches approximately 1.5 - 2 bar."
When I activate the electric pump, the pressure gauge on the tandem pump shows approximately 0.05 bar.
If I leave the car standing for about half an hour, it will start normally again.
The error codes LMM and G62 are present because I have disconnected something.
Here's the initial map; at 4.5°, it should normally request around 170 Nm of torque, which would correspond to approximately 29 mg/H.
Normally, the starting map wouldn't be set to 0. That was just a test to see if it would start.
I started with the characteristic map and then completed all the other tests.
| Description: |
| File size: |
24.12 KB |
| Viewed: |
929 times |
| Description: |
 Download |
| File name: |
Log-TMBBS61Z158xxxxx-132910km.txt |
| File size: |
10.46 KB |
| Downloaded: |
396 times |
VCDS
Translated on 25-10-2026, 12:37.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
06-11-2018, 22:10 Subject: Skoda Octavia BKC: Cold Start Problems |
Quote: | | Then I disconnected the coolant temperature sensor, but it still doesn't start any better. Finally, I checked what temperature the control unit displays in the diagnostic module (MWB) when the G62 sensor is disconnected. I always thought it would show negative values, but in this case, it shows 40-44° when the connector is removed. Then I used a 4.7k resistor, and in the MWB, it shows 4.5°. That also seems too high for a 4.7k resistor. |
Apart from the dataset of your modifications, is it original and compatible with the engine/control unit?
Translated on 25-10-2026, 12:40.
Profile PM WWW Garage |
07-11-2018, 12:47 Subject: Skoda Octavia BKC: Cold Start Problems |
According to Partslink, a 016BE part should be installed.
I didn't check if it's modified, but when I imported it, it suggested a 100% identical one, and it's an older model. I'll still check to see if it's an original.
VCDS
Translated on 25-10-2026, 12:41.
07-11-2018, 19:35 Subject: Skoda Octavia BKC: Cold Start Problems |
If it's the original equipment, I would check the various connection cables for damage caused by rodents or similar factors. The incorrect readings can only be caused by a limited number of reasons...
Translated on 25-10-2026, 12:42.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1513 Karma: +647 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
08-11-2018, 11:11 Subject: Skoda Octavia BKC: Cold Start Problems |
Is the idle speed too low?
Profile PM Garage |
08-11-2018, 18:59 Subject: Skoda Octavia BKC: Cold Start Problems |
Rüdi wrote: | | Is the idle speed too low? |
In Startmenge.jpg, he allowed the fuel injection amount to be set from an engine speed of 0.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
09-11-2018, 20:59 Subject: Skoda Octavia BKC: Cold Start Problems |
Quote: | | Then I measured the fuel pressure at the tandem pump, which was 2.7 bar at idle. It should be at least 3.5 bar. When I restrict the return flow, it increases to over 10 bar, so the PD-O-rings should also be OK. |
Unfortunately, that only indicates that a pressure of 10 bar is being built up. There are also enough cases where a higher pressure can shift or push the sealing rings to a different position, which could potentially lead to a seal again.
How does the pressure build up in a cold state?
If the engine is warm enough to trigger the starting process and the fuel injectors are being activated, then air is likely the only remaining cause... unless the intake passages are blocked, such as by a throttle valve or a shut-off valve.
Translated on 25-10-2026, 12:44.
10-11-2018, 13:50 Subject: Skoda Octavia BKC: Cold Start Problems |
I haven't measured it when it's cold, but it starts up immediately even then.
If it doesn't start, I have a starting speed of 250 RPM, which is why I also adjusted the fuel injection start curve. I haven't checked yet whether the PDEs are being activated.
Of course, I checked the throttle and shut-off valve.
VCDS
Translated on 25-10-2026, 12:45.
