Garrett Turbocharger: Original Part, Oil to Exhaust
ascendens
Post09-08-2018, 12:47    Subject: Garrett Turbocharger: Original Part, Oil to Exhaust Quote
Hello, I need some help again. I just bought a genuine Garrett turbocharger.
Before installation, I tested the oil line (feed line) for functionality. A container with a capacity of approximately 2 liters was placed under the connection point for the turbocharger. The engine was started, and the container filled with oil within 10 seconds.
Could it be that the oil pump is supplying too much oil pressure to the turbocharger?
The oil pipe return line was checked for flow back to the oil pan, and it was working correctly.
Turbocharger installed, but initially without the EGR pipes. The exhaust pipe was temporarily removed. The engine was started for 20 seconds. Afterwards, a slight oil film was visible on the exhaust side, while the compressor side was dry.
After installing all the AGR pipes, I started the engine. After 30 seconds, I noticed oil leaking and accumulating on the exhaust side. It was a slow leak.
I called Turbotechnik Altmark, and they told me that it had happened before that the oil pump generated too much pressure, but it could also be the KGE (Kühler-Getriebe-Einheit).
Does anyone here have experience with icon_rolleyes.gif?
Audianer Audi A4 2.0 TDI 8E B7 BPW Quattro
Translated on 16-10-2026, 12:00.
dieselschrauber likes this.
Post09-08-2018, 16:16    Subject: Garrett Turbocharger: Original Part, Oil to Exhaust Quote
Just check the oil pressure.
Translated on 16-10-2026, 12:02.
chli1976
Post10-08-2018, 16:22    Subject: Garrett Turbocharger: Original Part, Oil to Exhaust Quote
It's almost certainly the crankcase ventilation system.
If it's about the engine in your signature, replace the valve cover!
VCDS
ascendens
Post10-08-2018, 20:42    Subject: Garrett Turbocharger: Original Part, Oil to Exhaust Quote
Hi, I haven't gotten around to measuring the crankcase pressure yet, but could someone explain how a valve cover is supposed to work? If there's too much pressure, shouldn't it release when I open the oil cap? But that doesn't change the symptoms I'm experiencing.
In 10 seconds, approximately 1.5 liters of oil came out of the turbocharger's oil supply line, which is really crazy.
But even if it's not related to opening the lid, it would still be interesting to know how a cylinder head cover works.
Translated on 16-10-2026, 12:03.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Whistle: Documentary Analysis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo Oil Leak: F9Q 1.9 DCI Engine Problems Diesel Engine Technology
No new posts Garrett Turbochargers: How to Identify Them? Diesel Engine Technology
No new posts Garrett Turbocharger Issues with VW Engines? Diesel Engine Technology
No new posts 2.0 TFSI 3.0 Engine expresses oil from all seals Gasoline Engine Technology
