Steering Wheel Position VW Polo 6R
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post23-08-2018, 15:18    Subject: Steering Wheel Position VW Polo 6R Quote
Does anyone know where I can find the simple steering wheel position (in degrees) for a Polo 6R with ESP?
Only one of the systems providing ESP and steering assistance delivers the steering angle speed, while the other provides no data from the steering angle sensor at all.
The steering angle sensor itself provides the steering wheel angle in degrees (°), as well as the rate of change (gradient) in degrees per second (°/sec) within the extended vehicle data bus (MVB). However, both values are provided as decimal numbers with 16 digits before the decimal point, as detailed in the appendix.
Here's the STG scan of the Polo:
Thursday, August 23, 2018, 2:45:34 PM: 64765
VCDS - A VAG/VAS emulator based on Windows, running on Windows XP x86.
VCDS version: RKS 18.2.1.0
Data as of: 20180302 DS287.1
http://shop.dieselschrauber.org/en
Vehicle Identification Number (VIN): WVWZZZ6RZEYxxxxxx License plate: [Insert license plate here]
Mileage: 17740 km. Repair order:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55
Vehicle Identification Number (VIN): WVWZZZ6RZEYxxxxxx Mileage:
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate control/heating unit - Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist System 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
Steering assist - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module (ECM) Label file: C:\Users\6R0-907-115.lbl
Part number SW: 6R0 907 115, Part number HW: 6R0 907 115.
Component: 2.0L R4/4V TFSI 0020
Revision: 5LH02--- Serial Number:
Encoding: 0403000C18070160
Operating number: WSC 00191 264 15243
VCID: 6FE605087E61F13CC8-803A
No error codes found.
Readiness: 0000 0000
Address 03: Brake Electronics (J104)
Label file: .DRV\6R0-907-37x-ESP90.clb
Part number SW: 6R0 907 379 BG, Part number HW: 6R0 907 379 AS.
Component: ESP9.0i front H03 0001
Serial number: --------------
Encoding: 21DD7885432802C7841C1E6AC256404D0904
Operating number: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 040C5AA48FE7E26405-8050
Address: Steering angle sensor (G085)
Label file: *DRV\6R0-959-654.clb
Part number SW: 6R0 959 654, Part number HW: 6R0 959 654.
Component: STEERING SENSOR H07 0070
Serial number: 01081304651311
Encoding: 01
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
FILE: EV_LWSKLOVW25X.rod
VCID: 7EF8284CE10B88B453-802A
Address 08: Climate Control/Heating Unit (J255)
Label file: 6R0-907-044.clb
Part number SW: 6R0 907 044 H, Part number HW: 6R0 907 044 H.
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3874FE548BAF7684D9-806C
Address 09: Central Electronics (J519)
Label file: .DRV\7H0-937-08x-09.clb
Part number SW: 7H0 937 090 B, HW: 7H0 937 090.
Part number: BCM PQ25 Max4 H74 0712.
Revision: B9074001 Serial Number: 0571 207130823
Encoding: 24B0293F08E12400932809916C0B05D15A80472F60011040200000030000
Operating number: WSC 00788 648 00255
VCID: 2D5ADF0074EDC32CBA-8078
Subsystem 1 - Part number: 1K0 955 559 AH Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 050713 05 54 0403
Encoding: 02302D
Subsystem 2 - Part number SW: 6R0 959 801 AT, HW: 6R0 959 801 AT, Label file: 6R0-959-801.CLB.
Component: J386__TSG_FT 003 8620
Serial number: KU0KU009081300011101.
Encoding: 0000A0
Subsystem 3 - Part number SW: 6R0 959 802 BE, HW: 6R0 959 802 BE, Label file: 6R0-959-802.CLB.
Component: J387__TSG_BT 003 8620
Serial number: KU0KU007081300011535
Encoding: 1000A0
Subsystem 4 - Part number: 1K8 951 171 A
Component: DWA sensor 00 001 0103.
Encoding: 000000
Subsystem 5 - Part number: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501.
Encoding: 000000
Subsystem 6 - Part number: 1K8 951 171 A
Encoding: 000000
Subsystem 7 - Part number SW: 5K0 959 542 C, HW: 5K0 959 542 C.
Component: E221__MFL-TAS H31 0037
Serial number: 0093387
Encoding: 020000
Address 10: Parking Assist 2 (J446) Label file: | DRV\6R0-919-475.clb
Part number SW: 6R0 919 475 C, HW: 7E0 919 475.
Component: PARK ASSIST 4K H11 0013
Revision: -------- Serial Number: 47331318603234
Encoding: 108004
ASAM Dataset: EV_VW250ParkiAssis2 S01008
FILE: EV_VW250ParkiAssis2.rod
VCID: 3E78E84CA18B48B413-806A
Address 15: Airbag (J23) Label file: | DRV\5K0-959-655.clb
Part number SW: 6R0 959 655 M, Part number HW: 6R0 959 655 M.
Part number: VW10Airbag0C3 H10 0020
Revision: -------- Serial number: 003GZ001D93.
Encoding: 004333
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4C9CB284E737EA248D-8018
Crash sensor for driver-side side airbag:
Serial number: 3575HRB406522BUO2964.
Crash sensor for side airbag, passenger side.
Serial number: 3585HRB400U50I7ECPO0
Rear side airbag crash sensor (driver's side).
Serial number: 3515RRB401I50KR4DPJ0
Rear side airbag crash sensor, passenger side.
Serial number: 3525RRB401I50KR49P0L
Address 17: Control panel module (J285)
Label file: | DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 6R0 920 870 F, HW: 6R0 920 870 F.
Component: COMBINATION H04 0709
Serial number: 00000000000000
Encoding: 140E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 3874FE5483AF7684D9-806C
Address 19: Diagnostic interface (J533)
Label file: .DRV\6N0-909-901-6R.clb
Part number SW: 6N0 909 901, HW: 7H0 937 090.
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Encoding: 002000
VCID: 70E40674A35FEEC4D1-8024
Address 25: Immobilizer (J334)
Label file: | DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234, HW: 5K0 953 234.
Component: IMMO H04 0709
Serial number:
Encoding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD0141C8D8314149F-803E
Address 44: Steering Assist
Label file: DRV\6Q0-423-156.clb
Part number: 6R0 423 156 C
Component: Power Steering Unit - TRW - V278
Encoding: 11281
VCID: 3064C674F7DFAEC491-8064
Address 55: Headlight range adjustment (J431) Label file: .DRV\6R0-907-357.clb
Part number SW: 6R0 907 357, HW: 6R0 907 357.
Component: LWR-ECU (Low Beam Range Control Electronic Control Unit) H02 0070
Revision: -------- Serial Number: --------------
Encoding: 0112000001000000
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlightRegulationSoftware_VW25.rod
VCID: 77F63D68CE31B9FC10-8022
No error code(s) found.
LOG-04-IDE00327IDE00326_&8.xls
 Log vom Lenkwinkelsensor G085 im Stand, Lenkrad hin und her gedreht
 File name:  LOG-04-IDE00327IDE00326_&8.xls
 File size:  28.5 KB
 Downloaded:  338 times
Translated on 29-07-2026, 2:54.
Post23-08-2018, 18:36    Subject: Steering Wheel Position VW Polo 6R Quote
Hello Ulf,
The steering angle sensor has previously shown normal values (degrees) in my vehicles, so I suspect there might be a problem with your .xls conversion.
Have you already viewed the standard .csv file with KDataScope without any conversion?
Translated on 29-07-2026, 3:25.
Post23-08-2018, 18:49    Subject: Steering Wheel Position VW Polo 6R Quote
Hello Rainer,
I also see these strange 16-digit data in the "live screen" of the extended measurement values. I don't think there are any errors introduced on the way to the .xls file.
Here's the translation:
"What I've noticed is that only in the lumbar spine (LWS) section of the STI scan does an asterisk (*) appear before the label file. Could this possibly mean something?"
Translated on 29-07-2026, 3:26.
Post23-08-2018, 19:04    Subject: Steering Wheel Position VW Polo 6R Quote
ulf wrote:
Hello Rainer,
What I've noticed: Only in the lumbar spine (LWS) section of the CT scan is there an asterisk (*) before the label file. Could this possibly mean something?
Hmm, that's strange. Could you please post the .csv file from the log?
Translated on 29-07-2026, 3:27.
Post23-08-2018, 19:13    Subject: Steering Wheel Position VW Polo 6R Quote
Please provide the text you would like me to translate from German to English.
LOG-04-IDE00327IDE00326_&8.CSV
 File name:  LOG-04-IDE00327IDE00326_&8.CSV
 File size:  3.88 KB
 Downloaded:  298 times
Translated on 29-07-2026, 3:28.
Post23-08-2018, 20:05    Subject: Steering Wheel Position VW Polo 6R Quote
Hi Ulf,
I suspect there might be an incorrect conversion during the value calculation within VCDS.
Try using the latest beta version of VCDS.
http://www.ross-tech.com/vcds/download/beta/current.php
Post23-08-2018, 20:42    Subject: Steering Wheel Position VW Polo 6R Quote
It shouldn't be related to that. I also had a Polo 6R in the company car fleet.
"Ulf, did you perhaps capture the raw sensor data, not the values converted to degrees?"
Translated on 29-07-2026, 3:29.
Post24-08-2018, 7:34    Subject: Steering Wheel Position VW Polo 6R Quote
Hi Herbert,
Herbert wrote:
I also had the Polo 6R in my fleet.
I have the small series "WRC," where Polo and Golf technology (2-liter engine) were combined. Maybe something is already wrong there, e.g., with the conversions in the CAN bus. icon_confused.gif
I ran everything in the log that somehow relates to "angle," but nowhere do I see meaningful values.
@Rainer: I will test the beta version and get back to you with the results.
Translated on 29-07-2026, 3:30.
Post24-08-2018, 14:42    Subject: Steering Wheel Position VW Polo 6R Quote
Hi Rainer,
"The beta doesn't like my interface."
 File size:  56.18 KB
 Viewed:  613 times
Translated on 29-07-2026, 3:31.
Post24-08-2018, 16:19    Subject: Steering Wheel Position VW Polo 6R Quote
icon_confused.gif Okay... that's a shame, then all that's left is to wait for the next release....
Post24-08-2018, 16:34    Subject: Steering Wheel Position VW Polo 6R Quote
Could it possibly be because I'm still using an old laptop with Windows XP?
Translated on 29-07-2026, 3:32.
Post24-08-2018, 17:18    Subject: Steering Wheel Position VW Polo 6R Quote
ulf wrote:
Could it possibly be due to the fact that I'm still using an old XP laptop?
Hello Ulf,
pretty much ruled out.
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagnostic connector for the VW Polo 6N2 Diesel Engine Technology
No new posts Polo WRC Problems: Common Issues & Solutions On-Board Diagnostics (OBD)
No new posts Polo 86c: Reduce Diesel Particulate Filter (DPF) Diesel Engine Technology
No new posts Retrofit GRA for 9N SDI Polo Diesel Engine Technology
