Jens 16syncro
15-12-2017, 10:24 Subject: Broken 1.9 TDI AFN Camshaft: Causes & Fixes |
It's been a while, I'm back again.
Unfortunately, the reason for this is rather unpleasant: the AFN (automatic fuel mixture control) in my T3 has failed.
The camshaft is broken on cylinder 1.
The bearing surface shows significant wear, and the camshaft lobes are extremely dry. However, the other three cylinders are properly lubricated.
The oil pressure was good at the time of the incident, more than 5 bar.
However, the pressure sensor (pressure capsule) is located on cylinder 4, which is directly opposite.
Timing belt, etc. are all in excellent condition.
Has anyone ever experienced something like this before?
Jens.
Translated on 19-09-2026, 2:45.
vwSchrauber Profi-Schrauber
15-12-2017, 13:37 Subject: Broken 1.9 TDI AFN Camshaft: Causes & Fixes |
Quote: | The oil pressure was also good at the moment of the incident, more than 5 bar.
The measurement point (pressure sensor) is located on cylinder 4, so directly opposite. |
Theory: What if a hydraulic lifter became over-pressurized (due to high oil pressure and dirt in the inlet valve) and the camshaft forced the valve to hit a hard stop (valve contacts the piston)? selber schrauben - statt Werkstattpfusch
Translated on 19-09-2026, 2:47.
Herbert Profi-Schrauber
16-12-2017, 10:52 Subject: Broken 1.9 TDI AFN Camshaft: Causes & Fixes |
Given the age and mileage (?), or the damaged bearing(?), a fatigue fracture is also a possibility. The NW (presumably a component) is certainly not the weakest link in the chain if a valve sticks.
If the bearing had a lot of play (which is why?), it will naturally swing more within that range.
Herbert. Horch A4 8K CJCD
Translated on 19-09-2026, 2:48.
Jens 16syncro
28-08-2018, 11:03 Subject: Broken 1.9 TDI AFN Camshaft: Causes & Fixes |
Okay, I disassembled the engine quite some time ago, and unfortunately, I had to conclude that there was no oil pressure. Neither the oil pressure gauge nor the oil pressure switch were working correctly. However, I haven't yet figured out why there wasn't enough oil reaching the cylinder head. The oil pump looks completely normal, and the engine block itself doesn't show any signs of oil starvation, at least not visually. It's not easy to determine because several valves abruptly stopped two pistons during their upward movement.
The engine is in such poor mechanical condition that it's essentially scrap, and it's not worth repairing.
Translated on 19-09-2026, 2:49.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
dieselschrauber and Steffarn likes this. |
29-08-2018, 8:05 Subject: Broken 1.9 TDI AFN Camshaft: Causes & Fixes |
Low oil pressure can be caused by a pump that isn't generating enough pressure, or by a lack of counter-pressure due to wear.
The rear bearing of the intermediate shaft is a common failure point in these engines. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 19-09-2026, 2:50.
Profile PM Garage |
