Engine Failure Help: Oil Pressure Light?
Go to page: 1, 2, 3  Next
stolley
Karma: +38 / -1   Thank you, like it!
Post28-07-2017, 23:53    Subject: Engine Failure Help: Oil Pressure Light? Quote
Hello everyone,
My faithful Polo decided not to take me any further on the highway today.
Suddenly, I heard a "ping" sound, and the oil pressure warning light came on. I pulled over and checked the oil level. The oil level was fine. So, I started the engine again and tried to continue driving. I thought it might have just been a faulty reading from the oil pressure sensor or something similar.
After a short drive, the light came on again and the engine showed a loss of power.
The Polo was then towed away (it was a four-hour ordeal, but I met some nice people!).
I'm now thinking it's probably a faulty oil pump. I also listened to the engine again. I'll try to upload an audio sample.
What do you think? It sounds like there might be a problem in the area of the cylinder head.
I'm now unsure about what to do next: Should I remove the valve cover and inspect the camshaft, or should I order a new oil pump right away?
Here's the error scan:
Code:
Samstag,29,Juli,2017,01:48:49:25065
VCDS -- Windows-basierter VAG/VAS-Emulator l‰uft auf Windows XP x86
VCDS Version: RKS 16.8.3.4
Datenstand: 20161124 DS267.0
Fahrzeug-Ident.-Nr.: WVWZZZ9NZ8B03xxxx   KFZ-Kennzeichen:
Kilometerstand: 380080km   Reparaturauftrag: ÷ldruckleuchte
Fahrzeugtyp: 9N (9N3 - Polo)
Scan: 01 03 08 09 15 17 19 25 44 46 76
Fahrzeug-Ident.-Nr.: WVWZZZ9NZ8B03xxxx   Kilometerstand: 380080km
Adresse 01: Motorelektronik        Labeldatei: DRV\045-906-013-BMS.clb
   Teilenummer SW: 045 906 013 E    HW: 045 906 013 E
   Bauteil: R3 1,4L EDC G000SG  4271
   Revision: --H03---    Seriennummer: VWZ7Z0G5933092
   Codierung: 0003071
   Betriebsnr.: WSC 49000 143 80495
   VCID: 112F82EC0B0893CA5E-513C
1 Fehler gefunden:
001027 - Ventil f¸r Abgasr¸ckf¸hrung (N18)
               P0403 - 000 - Fehlfunktion - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00100000
                    Fehlerpriorit‰t: 1
                    Fehlerh‰ufigkeit: 3
                    Verlernz‰hler: 255
                    Zeitangabe: 0
                    Drehzahl: 0 /min
                    Geschwindigkeit: 4.0 km/h
                    Tastverh‰ltnis: 0.0 %
                    Spannung: 13.60 V
                    Luftmasse/Hub: 0.0 mg/H
                    Tastverh‰ltnis: 19.9 %
                    Bin‰rwert: 00110000
Readiness: 0 1 0 0 0
Adresse 03: Bremsenelektronik        Labeldatei: DRV\6R0-907-37x-ESP80.lbl
   Teilenummer SW: 6Q0 907 379 AS    HW: 6Q0 907 379 AS
   Bauteil: ESP 8.0 front   H05 0003
   Revision: 00000000    Seriennummer: 00000000000000
   Codierung: 0002365
   Betriebsnr.: WSC 00046 412 00000
   VCID: 0E1599901A368C3243-5178
Adresse 08: Klima-/Heizungsel.        Labeldatei: DRV\6Q0-820-045.lbl
   Teilenummer: 6Q0 820 045
   Bauteil: Klimaanlage        X0850
   VCID: 6ADDF500161E00127F-5178
Adresse 09: Zentralelektrik        Labeldatei: DRV\6Qx-937-049-C.lbl
   Teilenummer: 6Q1 937 049 F
   Bauteil: 0009 BN-SG.         2S36
   Codierung: 09646
   VCID: 3E7509503A165CB2F3-515A
Adresse 15: Airbag        Labeldatei: DRV\6Q0-909-605-VW5.lbl
   Teilenummer: 1C0 909 605 K
   Bauteil: 19 AIRBAG VW51 0P   0010
   Codierung: 12601
   VCID: 2C513318DC6ADE224D-515A
Adresse 17: Schalttafeleinsatz        Labeldatei: DRV\6Q0-920-xxx-17.lbl
   Teilenummer: 6Q0 920 825 F
   Bauteil: KOMBIINSTRUMENT VDO V06
   Codierung: 01132
   Betriebsnr.: WSC 00000
   VCID: 377B1C74152C6DFA30-515A
Adresse 19: Diagnoseinterface        Labeldatei: DRV\6N0-909-901-19.lbl
   Teilenummer: 6N0 909 901
   Bauteil: 01K1 GATEWAY CAN    2S36
   Codierung: 00014
   VCID: 70E9E76830C2FAC231-515A
Adresse 25: Wegfahrsperre        Labeldatei: DRV\5J0-920-xxx-25.clb
   Bauteil: IMMOBILIZER VDO V06
   Codierung: 01132
   WVWZZZ9NZ8B031810     VWZ7Z0G5933092
Adresse 44: Lenkhilfe        Labeldatei: DRV\6Q0-423-156.clb
   Teilenummer: 6Q0 423 156 AB
   Bauteil: LenkhilfeTRW        V270
   Codierung: 10110
   VCID: 6FEBE4142DFCE53A28-515A
Adresse 46: Komfortsystem        Labeldatei: DRV\6Q0-959-433.lbl
   Teilenummer: 6Q0 959 433 E
   Bauteil: 3F Komfortger·t     0002
   Codierung: 00019
   VCID: 3D770E5C371047AAEA-4B32
Adresse 76: Einparkhilfe        Labeldatei: DRV\7H0-919-283.lbl
   Teilenummer: 7H0 919 283 A
   Bauteil: Parkingsyst. 24 KUH 402
   Codierung: 00102
   VCID: 30692768F042BAC271-515A
Ende----------------------------(Dauer: 01:55)-----------------------------
Engine Failure Help: Oil Pressure Light? - IMG_0530.MOV
 File size:  39.37 MB
 Viewed:  849 times
Translated on 26-07-2026, 15:31.
stolley
Post29-07-2017, 7:26    Subject: Engine Failure Help: Oil Pressure Light? Quote
Does anyone happen to know if you have to remove the transmission to access the oil pan on this engine (BWB)?
Translated on 26-07-2026, 15:33.
chli1976
Karma: +185 / -0   Thank you, like it!
Post29-07-2017, 7:44    Subject: Engine Failure Help: Oil Pressure Light? Quote
Did you check the oil pressure with a gauge?
The oil pan should come off easily.
VCDS
Translated on 26-07-2026, 15:34.
stolley
Post29-07-2017, 8:02    Subject: Engine Failure Help: Oil Pressure Light? Quote
chli1976 wrote:
Have you checked the oil pressure with a gauge?
The oil pan is coming down like this.
No, not yet. I'm also not sure how to do that right now. What about the clicking sound? Thanks for the good news about the oil pan!
Karma: +1343 / -0   Thank you, like it!
Post29-07-2017, 9:04    Subject: Engine Failure Help: Oil Pressure Light? Quote
The rattling noises coming from the area of the cylinder head are likely caused by collapsed hydraulic lifters. The engine seems to be lacking oil lubrication, so you shouldn't run it unnecessarily for any tests.
Translated on 26-07-2026, 15:35.
chli1976
Post29-07-2017, 10:30    Subject: Engine Failure Help: Oil Pressure Light? Quote
Regarding the mileage, it might be a worn-out timing chain (I'm not sure if this affects the 3-cylinder engines), and possibly sticking hydraulic lifters, which could also lead to lower oil pressure, although I haven't experienced that yet; it's just a theory. If you remove the valve cover, check if the oil seals are present on the camshaft. (I only know about this from the 4-cylinder engines). However, the mass airflow sensor should detect this.
VCDS
Translated on 26-07-2026, 15:36.
stolley
Post29-07-2017, 14:09    Subject: Engine Failure Help: Oil Pressure Light? Quote
Herbert wrote:
The rattling noises coming from the area of the cylinder head are likely caused by collapsed hydraulic lifters. The engine seems to have no oil supply, so you shouldn't run it unnecessarily for pointless tests.
Thank you for the tip!
I thought I could run a test without too much risk because the oil pressure warning light doesn't come on when the engine is idling.
Translated on 26-07-2026, 15:37.
stolley
Post29-07-2017, 14:12    Subject: Engine Failure Help: Oil Pressure Light? Quote
chli1976 wrote:
Considering the mileage, it might be a worn-out timing chain (I don't know if the 3-cylinder engines are affected by this) and hydraulic lifters that are leaking, which could potentially lead to lower oil pressure, although I haven't experienced that yet; it's just a theory. If you remove the valve cover, also check if the oil seals are present on the camshaft. (I only know about this from the 4-cylinder engines). However, the mass airflow sensor should detect this.
I replaced the camshaft and lifters 20,000 km ago... I already know the sound of a faulty lifter! icon_wink.gif
"Oil cap doesn't mean anything to me, but I'll open it up and remove the oil pan."
Or do you have any other tips on how to proceed?
Thank you in advance!
Translated on 26-07-2026, 15:39.
chli1976
Post29-07-2017, 17:17    Subject: Engine Failure Help: Oil Pressure Light? Quote
I'd like to measure the oil pressure using a gauge. Disconnect the oil pressure switch and connect the gauge directly. Remove the oil pan and check the strainer at the suction port for any blockages; these often get clogged over time.
VCDS
Translated on 26-07-2026, 15:40.
Post29-07-2017, 17:31    Subject: Engine Failure Help: Oil Pressure Light? Quote
Just a side note: The warning light doesn't come on until a certain engine speed threshold is reached... you can let it idle until it seizes up.
Translated on 26-07-2026, 15:41.
Mpire
Avatar-Mpire
2019 Skoda Octavia
stolley likes this.
Post29-07-2017, 20:46    Subject: Engine Failure Help: Oil Pressure Light? Quote
"There have also been frequent cases of broken timing chains in the balance shaft module, particularly in the 1.4 TDI engines found in the 9N and similar models."
The oil pump is also driven by the chain, which usually sits inside the oil pan.
The automatic gearbox (AGW) and oil pump would stop working. This would prevent the engine from starting.
Remove the bathtub, replace the chain and tensioner, and it should run for a while longer.
provided that the cylinder liners and connecting rod bearings are still in good condition.
But be careful: the AGW (automatic gear warmer) must be brought to a standstill with the engine in a specific position before the chain can be pulled.
Mpire
 File size:  1.65 MB
 Viewed:  5690 times
Translated on 26-07-2026, 15:42.
stolley
Post29-07-2017, 22:35    Subject: Engine Failure Help: Oil Pressure Light? Quote
matthiasTDI96 wrote:
Just a side note. The warning light doesn't come on until a certain speed threshold is reached... you can let it run in neutral until it seizes.
Oh, I didn't know that...
It's kind of illogical, isn't it?
Translated on 26-07-2026, 15:43.
stolley
Post29-07-2017, 22:41    Subject: Engine Failure Help: Oil Pressure Light? Quote
Mpire wrote:
There have also been frequent cases of broken chains on the balance shaft module, particularly in the 1.4 TDI engines in the 9N and similar models.
Greetings Mpire
Hello Mpire,
Thank you for the tip and the encouraging words!
I'm a bit worried now, after the recent descriptions, that the engine may have sustained further damage as a result of the renewed test drive (see above).
What kind of damage can a motor sustain when it's running with little or no oil? When I let the engine idle, I also looked into the oil filler opening, and it definitely didn't look dry in there...
Translated on 26-07-2026, 15:45.
Post30-07-2017, 8:24    Subject: Engine Failure Help: Oil Pressure Light? Quote
Don't mess around, measure the oil pressure with a gauge, otherwise don't run the engine anymore.
Translated on 26-07-2026, 15:47.
stolley
Post30-07-2017, 11:21    Subject: Engine Failure Help: Oil Pressure Light? Quote
What would be considered normal values for oil pressure?
stolley
dieselschrauber likes this.
Post30-07-2017, 18:41    Subject: Engine Failure Help: Oil Pressure Light? Quote
Mpire wrote:
There have also been frequent cases of broken chains on the balance shaft module, especially in the 1.4 TDI engines in the 9N and similar models.
Greetings Mpire
Hello Mpire!
Your guess was spot on: the chain broke!
Zusätzlich ist ein Zahn vom Zahnrad der Ausgleichswelle abgebrochen - vgl. Photo.
My question to you or anyone else who can help (thank you in advance!):
According to the Volkswagen manual (which I have), I need to remove the balance shaft. To do that, I also need to remove the sealing flange, and to remove the sealing flange, I need to remove the timing belt.
Is that really the case? It wouldn't be a big deal; I've done it multiple times before with my Polo.
And another question about the special tools required: Are all of the tools listed in the VW manual absolutely necessary, or can some of them be substituted with alternatives? I already have the locking tool for timing belt replacement.
What surprises me is that the chain didn't destroy everything around it... Was I lucky? Or do I need to investigate this further? At least, in the oil pan, there was only the broken tooth and small pieces (presumably from the chain).
And now let the photos speak for themselves:
 File size:  3.22 MB
 Viewed:  1132 times
 File size:  2.71 MB
 Viewed:  1109 times
 File size:  2.75 MB
 Viewed:  1141 times
Translated on 26-07-2026, 15:50.
No new posts Hilfe, Hilfe Schlechter Durchzug beim 150 PS TDI Diesel Engine Technology
No new posts A6 V6 TDI Engine Failure? Diesel Engine Technology
No new posts Engine failure in A6 at 110,000 km Diesel Engine Technology
No new posts Engine Failure AFN: Causes & Repair Diesel Engine Technology
