Finding an OT with a multimeter.
hammuts
Post19-10-2018, 10:03    Subject: Finding an OT with a multimeter. Quote
Can the OT also be found using a multimeter on the sensor of the AFN?
Thank you and best regards.
Back to top Profile PM Email
Post19-10-2018, 19:35    Subject: Finding an OT with a multimeter. Quote
No,
There is a tachometer, but no oil pressure sensor.
Also, its signal should also not be easily visible with a multimeter in a quasi-static state.
What is the real problem?
lampenmann
Deus Violentia likes this.
Post20-10-2018, 11:47    Subject: Finding an OT with a multimeter. Quote
You can easily find the OT by marking it on the flywheel. It will either be a 0 or an I. You can see this marking through a hole in the gear housing.
In the hole, the exact position is marked by a casting spout. This applies to both horizontal and vertical installations.
Ste.Bo
Karma: +90 / -0   Thank you, like it!
Post20-10-2018, 16:00    Subject: Finding an OT with a multimeter. Quote
I fully understand the question. The muzzle guard is no longer (apparently) visible on one of my AFNs!
Post20-10-2018, 16:44    Subject: Finding an OT with a multimeter. Quote
The nozzle is located exactly in the center of the gear bell, simply take the center of the hole if no nozzle is visible.
Best regards, Rainer
Post20-10-2018, 16:52    Subject: Finding an OT with a multimeter. Quote
At 1Z, it's the "reference edge" of the viewing hole, not a nose. Perhaps it's also the case with AFN. icon_idea.gif
At least here, yes
/viewtopic.php?t=27184
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Herbert likes this.
Post20-10-2018, 18:11    Subject: Finding an OT with a multimeter. Quote
Herbert wrote:
For 1Z, it's the "reference edge" of the viewing window, not the nose. Perhaps it's also the case with AFN. icon_idea.gif
At least here, yes
Golf 3 and similar models with aftermarket gearboxes, specifically those with 02A gearboxes, are considered to have a "short throw".
Long-running installations for Audi A4 B5, Passat 3B etc. "Trim edge" (the photo posted by Herbert, link)
No new posts VP 37 Pump Tuning: Tools & Guide Diesel Engine Technology
No new posts Where can I find the coolant temperature sensor G62? Diesel Engine Technology
No new posts I can't find it... Diesel Engine Technology
No new posts Drive Shaft Joint: Not Found? Find It Here! Transmission, Chassis, Body & Interior
