hammuts
19-10-2018, 10:03 Subject: Finding an OT with a multimeter. |
Can the OT also be found using a multimeter on the sensor of the AFN?
Thank you and best regards.
Profile PM Email |
Herbert Profi-Schrauber
19-10-2018, 19:35 Subject: Finding an OT with a multimeter. |
No,
There is a tachometer, but no oil pressure sensor.
Also, its signal should also not be easily visible with a multimeter in a quasi-static state.
What is the real problem?
lampenmann
Deus Violentia likes this. |
20-10-2018, 11:47 Subject: Finding an OT with a multimeter. |
You can easily find the OT by marking it on the flywheel. It will either be a 0 or an I. You can see this marking through a hole in the gear housing.
In the hole, the exact position is marked by a casting spout. This applies to both horizontal and vertical installations.
Ste.Bo Profi-Schrauber
20-10-2018, 16:00 Subject: Finding an OT with a multimeter. |
I fully understand the question. The muzzle guard is no longer (apparently) visible on one of my AFNs!
20-10-2018, 16:44 Subject: Finding an OT with a multimeter. |
The nozzle is located exactly in the center of the gear bell, simply take the center of the hole if no nozzle is visible.
Best regards, Rainer
Profile PM WWW Garage |
20-10-2018, 16:52 Subject: Finding an OT with a multimeter. |
At 1Z, it's the "reference edge" of the viewing hole, not a nose. Perhaps it's also the case with AFN.
At least here, yes
/viewtopic.php?t=27184
Gremlin Schrauber
Joined: 08/18/2005 Posts: 396 Karma: +92 / -0 Location: Grainet 2000 Audi A4 Avant  Premium Support
Herbert likes this. |
20-10-2018, 18:11 Subject: Finding an OT with a multimeter. |
Herbert wrote: | For 1Z, it's the "reference edge" of the viewing window, not the nose. Perhaps it's also the case with AFN.
At least here, yes
Herbert |
Golf 3 and similar models with aftermarket gearboxes, specifically those with 02A gearboxes, are considered to have a "short throw".
Long-running installations for Audi A4 B5, Passat 3B etc. "Trim edge" (the photo posted by Herbert, link)
That's how I know it;
Profile PM Garage |
