haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
25-11-2018, 20:48 Subject: DPF Problems: Causes, Solutions & Repair |
"viewtopic.php?p=244487#244487"
Comparing this with my data, as seen in post 14.11, the 0.13 L oil ash volume cannot correspond to either the calculated 8.33 grams or the measured -0.13 grams. There is definitely at least one sensor that is defective.
haithamina
Translated on 01-10-2026, 11:20.
TTaurus
25-11-2018, 20:57 Subject: DPF Problems: Causes, Solutions & Repair |
haithamina wrote: | When I compare this with my data, see posting 14.11, the 0.13 L oil ash volume neither corresponds to the calculated 8.33 grams nor the measured -0.13 grams. There is definitely at least one sensor that is defective.
haithamina |
STOP.
That has nothing to do with each other!
Or am I misunderstanding something here?
I'm interested in the relationship between the calculated and measured soot values.
Is it an EU6 engine?
Translated on 01-10-2026, 11:22.
Herbert Profi-Schrauber
26-11-2018, 9:11 Subject: DPF Problems: Causes, Solutions & Repair |
The soot level can certainly be slightly negative after a regeneration process. Specifically, the measured value is determined based on the differential pressure.
Most likely, the soot level, which previously drops below zero, triggers the end of the regeneration process.
Translated on 01-10-2026, 11:23.
26-11-2018, 10:25 Subject: DPF Problems: Causes, Solutions & Repair |
TTaurus wrote: | haithamina wrote: | When I compare this with my data, see posting 14.11, the 0.13 L oil ash volume neither corresponds to the calculated 8.33 grams nor the measured -0.13 grams. There is definitely at least one sensor that is defective.
haithamina |
STOP.
Is it an EU6 engine? |
Yes, I was referring to the ratio of ash volume to ash mass. The values posted so far show a significantly different relationship.
Yes, the data I posted comes from a EU6 CR diesel engine with a storage catalytic converter (without SCR).
haithamina
Translated on 01-10-2026, 11:24.
