OBD2 Diagnostic Kit: Troubleshooting Guide
hukuluku
2009 Volkswagen Golf
Post11-12-2018, 14:33    Subject: OBD2 Diagnostic Kit: Troubleshooting Guide Quote
Hello everyone,
I recently bought an OBD2 diagnostic kit.
https://shop.dieselschrauber.org/en/obd2-diagnose-kit-p-321-l-de.php
I installed the drivers even before I connected the adapter.
However, I'm no longer sure if I entered the correct login credentials when I first started the software.
"Definitely, I can't read any vehicle data with KOBD2CHECK."
The software indicates in the bottom right corner that the connection to the adapter is okay, but I'm not receiving any data.
Could this error be caused by incorrect login credentials, and if so, how can I correct them?
Uninstalling and then reinstalling did not improve the situation.
I hope someone can help me.
hukuluku
Translated on 31-10-2026, 7:55.
Post11-12-2018, 19:51    Subject: OBD2 Diagnostic Kit: Troubleshooting Guide Quote
Could this error be due to incorrect login credentials being entered, and if so, how can I correct them?
No. If the data were incorrect and an internet connection exists, the program will automatically prompt for the information again. icon_smile.gif
The login credentials are only required in KOBD2Check so that the program can synchronize engine control unit data with the Dieselschrauber server in order to display information about CVN (Customer Vehicle Number) and software version.
Could you tell us which vehicles you have tested?
Please upload a Screenshot of KOBD2Check after clicking the "Info" button as an attachment.
Translated on 31-10-2026, 7:57.
hukuluku
dieselschrauber likes this.
Post17-12-2018, 16:34    Subject: OBD2 Diagnostic Kit: Troubleshooting Guide Quote
Thank you for your reply, and sorry for my late response.
The vehicle I was trying to read data from was a Nissan Micra, model year 2008.
Unfortunately, I can no longer take a Screenshot because the car is no longer available.
I have just discovered that the same error message appears if the OBD cable is not connected to the vehicle, or if the connector is not fully inserted.
The adapter was successfully tested today on a Golf 6, and everything worked perfectly.
M. Krause.
Translated on 31-10-2026, 7:58.
Post17-12-2018, 18:45    Subject: OBD2 Diagnostic Kit: Troubleshooting Guide Quote
Translated on 31-10-2026, 7:59.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VAG-COM/OBD2: Third-Party Diagnostic Software On-Board Diagnostics (OBD)
No new posts VCDS/OBD2 Diagnostic Tool for Sale On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts OBD2 Adapter: MFA via OBD2 Diesel Engine Technology
