Idle speed control for the 2.5 TDI BDH engine
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post09-07-2019, 8:43    Subject: Idle speed control for the 2.5 TDI BDH engine Quote
Hello everyone,
Unfortunately, I've noticed that my BDH 2.5 TDI is starting a bit poorly. I've tested the coolant temperature sensor, and it seems to be working fine. The spark plugs are also new.
The engine looks quite good through the oil filler cap opening. The engine runs smoothly and pulls cleanly.
Could you tell me something about idle speed control? What exactly do the negative signs mean?
The mileage is documented as 212,000 km. Year of manufacture: 2004.
The measurements were taken with the engine running warm.
Thank you.
 File size:  7.59 MB
 Viewed:  732 times
 File size:  6.78 MB
 Viewed:  696 times
Beste Grüße,
Hufe
Post11-07-2019, 18:48    Subject: Idle speed control for the 2.5 TDI BDH engine Quote
When there is a negative injection quantity correction, the corresponding cylinder must inject less fuel in order to achieve a constant angular velocity at the crankshaft.
Since all the cylinders are showing negative values, cylinder 2 (the reference cylinder) is likely the problem, as it requires more fuel injection. The sum of all correction factors is 0.
I can't imagine the engine is running smoothly, but you're standing in front of the car and you have to think it's okay. Possibly. Upload video here?
If you see a need for action:
- Check the camshaft and rocker arms.
- Check compression.
- Check the nozzle holder assembly.
... would proceed in this order.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Idle Speed Control Valve 38mm Diesel Engine Technology
No new posts AVF Idle Speed Control - Cylinder 3 On-Board Diagnostics (OBD)
No new posts Idle speed control Diesel Engine Technology
No new posts Idling Oxygen Sensor: Causes of -2.4mg/H Reading Diesel Engine Technology
