Seal AGR cooler bypass valve on CR-V6 TDI (Solution)
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber, Rüdi and Martininii likes this.
Post10-02-2019, 13:58    Subject: Seal AGR cooler bypass valve on CR-V6 TDI Quote
Sealing AGR: I've finally found and tested a simple and cost-effective solution for the leaking AGR cooler bypass valve on CR-V6-TDIs.
The constant smell of exhaust fumes, especially during the regeneration process, is unpleasant.
So:
- Remove the pressed-in lever (remove the pressed-on collar with a Dremel).
- Remove the lever.
- Clean the wave and seat in the AGR cooler.
- Press in the heat-resistant oil seal, size 8x14x4 (part number 020311108A).
- Cut M3 threads into the shaft.
- Reattach the lever and enjoy.
The shaft seal costs €6.95 and 30 minutes of labor.
On the other hand, a new AGR cooler costs 390 euros or more, and requires approximately 8 hours of labor.
Martin
 File size:  1.22 MB
 Viewed:  1002 times
 File size:  1000.55 KB
 Viewed:  1044 times
Ratings - Seal AGR cooler bypass valve on CR-V6 TDI
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 3 - View ratings
No new posts Seal Hubdüse SWA: How to & Best Practices Transmission, Chassis, Body & Interior
No new posts Seal Tandem Pump: How To & Best Practices Diesel Engine Technology
No new posts Valve Cover Gasket: Reviews & Sealing Tips (ASZ) Diesel Engine Technology
No new posts Sealing the injection pump on a AAT 2.5 TDI? Diesel Engine Technology
