Passat BMR Turbo Failure: Excessive Smoke from Crankshaft
Lars
Post10-02-2019, 9:30    Subject: Passat BMR Turbo Failure: Excessive Smoke from Crankshaft Quote
Hello.
from North Rhine-Westphalia and the Lippe region.
I'm Lars, I'm 42 years old, and I found this forum after purchasing the VCDS software.
I drive a 2008 Passat with a BMR engine.
Last summer, while I was on vacation in Denmark, the oil pump drive broke down.
The vehicle was towed home, and I had the AGM module refurbished.
Everything went perfectly; the engine ran without any problems.
At 215,000 km (approximately 133,000 miles), and now about 10,000 km (6,200 miles) later, roughly two weeks ago, we started hearing the turbocharger when accelerating; it was getting louder.
I actually want to fix this now. Yesterday, I pulled out the dipstick while the engine was running, and a lot of smoke came out.
It wasn't like that before.
I removed the hose in front of the turbo, and it's heavily contaminated with oil and sludge.
The turbo's wave has a lot of room to develop.
Now my question is: where does the smoke come from?
Motor selber?? Piston rings?
Or perhaps due to a turbocharger that is no longer functioning properly?
I would be grateful for any advice or tips.
Happy Sunday everyone!
Lars.
Translated on 28-07-2026, 14:03.
Karma: +643 / -0   Thank you, like it!
Post10-02-2019, 9:57    Subject: Passat BMR Turbo Failure: Excessive Smoke from Crankshaft Quote
Is the turbo broken now, or not?
Was the rate of error development lower before than it is now?
Translated on 28-07-2026, 14:06.
Lars
Post10-02-2019, 10:01    Subject: Passat BMR Turbo Failure: Excessive Smoke from Crankshaft Quote
The turbo is definitely broken.
The smoke coming from the crankcase wasn't there before.
Sure, it's a bit clearer, but nowhere near as extreme.
dieselschrauber and Lars likes this.
Post10-02-2019, 12:59    Subject: Passat BMR Turbo Failure: Excessive Smoke from Crankshaft Quote
I would now perform a compression and leakdown test before disassembling anything on the engine.
Translated on 28-07-2026, 14:07.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Doku Passat MKB AVB, Kraftstoffverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Failure: Smoke and Performance Issues Diesel Engine Technology
No new posts starke Rauchentwicklung in Warmlaufphase bei 2500 u/min Diesel Engine Technology
No new posts AFN - Fehlzündungen, starke Rauchentwicklung, stottern Diesel Engine Technology
No new posts A4 8E Rauchentwicklung Diesel Engine Technology
