After the ZK change, I need to re-implement the PDE. What are the torque values? Are they freely adjustable? Or must they be fixed in place?
Thank you all
For a small price, you can find the right repair manual, including torque specifications, at Erwin's.
What do you mean by "they have to be positioned correctly in your mind"? You take the parts, insert them into the holes on the cylinder head, and tighten them (short version).
First of all, thank you for the response. The BMR has a mounting plate with two holes for the screws.
It's been 6 weeks since I disassembled it.
I no longer remember how deep they were in the holes.
If I insert it like this, there will be approximately one [unit of measurement] space between the element and the ZK.
cm space. I think that's wrong. But I haven't checked it with the feeler gauge yet.
"You can see how the PD units were installed, of course, perfectly clean, otherwise how could it be?"
I think that, in your case, a repair manual is a very worthwhile investment; the potential damage caused by incorrect installation is absolutely not worth the cost of the manual.
Please also ensure that the PD unit settings are configured correctly.
