Sharan AUY Gas Pedal
chli1976
Post30-05-2019, 16:36    Subject: Sharan AUY Gas Pedal Quote
Sharan AUY, born in 2002, sometimes doesn't add gas, the pre-glow lamp lights up, and the idle speed is increased.
Error Storage:
Address 01: Engine Electronics Label File: DRV\038-906-019-AJM.lbl
ECU Part Number: 038 906 019 FC
Part and/or Version: TuneLine V25G001SG 1562
Encoding: 00002
Operating Number: WSC 00106
Extended Information: WVWZZZ7MZ3V020034 VWZ1Z0B2249844
VCID: 5D7328C38FA9DDEADE-4B18
2 error codes found:
17664 - Coolant Temperature Sensor (G62)
P1256 - 35-10 - Intermittent/Short Circuit after + - Sporadic
18047 - Sender 1/2 for Throttle Position (G79)+(G185)
P1639 - 35-00 - Unrealistic Signal
Readiness: Not Available
If you look at MWB 6 or 10, it can detect the accelerator pedal position (even when in emergency mode).
With the newer Sharans, there's a TPI that allows you to swap the contacts.
Could it also be due to this, but why does he not know the position in the MWB?
Or is there something wrong with the tuning, but it's been on for a while?
Someone has experienced something similar before.
VCDS
Post31-05-2019, 11:43    Subject: Sharan AUY Gas Pedal Quote
If the other fault with the coolant temperature sensor occurred promptly, I would rather suspect chafing of the wiring harness to the engine control unit.
Best regards, Rainer
dieselschrauber likes this.
Post03-06-2019, 11:17    Subject: Sharan AUY Gas Pedal Quote
Or Cable breaks in the area of transition from chassis to engine...
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error 18047 - Accelerator Pedal Sensor Diesel Engine Technology
No new posts VW Sharan 16705 - Geber für Motordrehzahl (G28) Diesel Engine Technology
No new posts Adjust Gas Pedal: How-to Guide & Tips Diesel Engine Technology
No new posts Accelerator characteristics AHF Electrical Systems, Vehicle Electronics, Multimedia
