Reverse Camera Replacement Audi A3 8V
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
HamSt
Post19-05-2019, 0:04    Subject: Reverse Camera Replacement Audi A3 8V Quote
Hello everyone,
"The rear-view camera on my A3 8V (MJ2013) has stopped working. Instead of the camera image, the MMI only displays the visual parking assist."
The following entries are stored in the error memory.
I would be grateful for a troubleshooting tip icon_smile_thumb_up.gif.
Saturday, May 18, 2019, 12:03:11:50428
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x64.
VCDS Version: RKS 18.2.1.0 HEX-V2 CB: 0.4437.4
Data as of: 20180313 DS287.1
http://shop.dieselschrauber.org/en
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F 69 6C A5 BB BC
Vehicle Identification Number:
Mileage: 59292 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
5F-Information Selection. I -- Status: Error 0010.
69 followers -- Status: OK 0000
6C Rear-view camera -- Status: Error 0010.
A5 Front/Forward-facing camera -- Status: OK 0000
Rear left door electronics -- Status: OK 0000.
Rear right door electronics - Status: OK 0000.
Address 09: Central Electronics (J519)
Label file: | 5Q0-937-08X-MV1.clb
Part number SW: 5Q0 937 084 T. Part number HW: 5Q0 937 084 T.
Component: BCM MQBAB M+ H14 0112.
Serial number: 00011326200480
Encoding: 04020D46C2C1067D4384400400140708000C000000000000000000000000
Operating number: WSC 06314 790 00021
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_011.rod
VCID: 49CEAC5479354D8FE6F-801C
Wiper motor control unit:
Subsystem 1 - Part number SW: 8V1 955 119 A, HW: 8V1 955 119, Label file: DRV\5QX-955-119-V1.CLB.
Component: WWS370 130913 041 0580
Serial number: 130916141713
Encoding: 0A47F7
Rain and light sensor:
Subsystem 2 - Part number SW: 8U0 955 559 A, HW: 8U0 955 559 A, Label file: DRV\8U0-955-559.CLB.
Component: G397_RLS H06 0002
Serial number: 20124122
Encoding: 00006C
Light switch:
Subsystem 3 - Part number SW: 8V0 941 531 G HW: 8V0 941 531 G
Component: E1 - LDS MQB H05 0032.
Serial number: 06 07 2013 00000141
"One error found:"
395521 - Function limitation due to active anti-tamper function.
B2023 00 [008] - -
[Overload of surge protection counter]
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 6
Error frequency: 5
Lost Count: 18
Mileage: 59,228 km
Date: 2019.05.15
Time: 20:53:59
Address 10: Parking Assist 2 (J791) Label file: | DRV\5Q0-919-298.clb
Part number SW: 5Q0 919 298 B, HW: 5Q0 919 298 B.
Component: PARKHILFE PLA H11 0033
Revision: -------- Serial Number: 61131310000844
Encoding: 0010161141
ASAM Dataset: EV_EPHVA2CAU3700000 003015
ROD: EV_EPHVA2CAU3700000_003_AU37.rod
VCID: 3E24CF8830FBFA3743D-806A
No error codes found.
Address 5F: Information selection. I (J794) Label file: | 8V0-035-MIB-STD1.clb
Part number SW: 8V0 035 840 B, HW: 8V0 035 840 B.
Component: MU-S--ER 040 0420
Serial number: A3E02409132517
Encoding: 01730300FF00000011110001000A00002F0001040100010002
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3430EDA00EB72067A59-8060
Display unit 1 for the multimedia system:
Subsystem 1 - Part number SW: 8V0 919 603 A, HW: 8V0 919 603 A.
Component: DU Std H48 0013.
Serial number: AUZ8Z9DG602NSV
Control unit for multimedia system:
Subsystem 2 - Part number SW: 8V0 919 614 B, HW: 8V0 919 614 B.
Component: ControlUnit_B H33 0037
Serial number: C1000029071300020193
2 error codes found:
6923 - Functionality restriction due to missing message.
U1111 00 [009] - -
[Rear-view camera (0x0B) - function restricted due to communication error - BapErr_timeout: heartbeat]
Error priority: 6
Error frequency: 1.
Lost Count: 233
Mileage: 59292 km
Date: 2019.05.18
Time: 11:57:43
Voltage at terminal 30: 12.0 V.
7179 - Functionality restricted due to missing message.
U1111 00 [009] - -
[Rear-view camera (0x0B) - function restricted due to communication error - BapErr_retry unsuccessful]
Error priority: 6
Error frequency: 7
Lost Count: 233
Mileage: 59,228 km
Date: 2019.05.15
Time: 20:40:48
Voltage at terminal 30: 12.1 V.
BAP-BAP_Function_ID: 01
Address 6C: Rear view camera (J772)
Label file: | 5Q0-907-441.clb
Part number SW: 5Q0 907 441 HW: 5Q0 907 441
Part: MQB RVC Mid
H06 0120
Encoding: 027300010301000700
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 6FBA22CC271143BF98B-803A
"One error found:"
10487040 - Invalid dataset.
B2005 00 [009] - -
[ECU (DatasetDownload)_Dataset is not valid]
Error priority: 2
Error frequency: 1.
Lost Count: 229
Mileage: 59,228 km
Date: 2019.05.15
Time: 20:40:45
aus
Translated on 23-09-2026, 21:35.
Post19-05-2019, 7:33    Subject: Reverse Camera Replacement Audi A3 8V Quote
Hello.
Address 6C: Reverse camera (J772) Label file: | 5Q0-907-441.clb
Part number SW: 5Q0 907 441, Hardware number: 5Q0 907 441.
Part: MQB RVC Mid H06 0120
Operating number: WSC 06314 790 00021.
"One error found:"
The backup camera says its firmware is corrupted.
I would like to briefly disconnect the vehicle's battery and check if there is any evidence of water ingress at the rear, or if the control unit has been flooded.
Translated on 23-09-2026, 21:53.
HamSt
Post19-05-2019, 22:07    Subject: Reverse Camera Replacement Audi A3 8V Quote
Hello Rainer,
Thank you for the tip. Unfortunately, disconnecting the battery didn't help, and there's no evidence of water damage. Is it possible to reinstall the firmware, or is the control unit likely damaged?
Translated on 23-09-2026, 21:55.
vag-driver
dieselschrauber likes this.
Post20-05-2019, 6:45    Subject: Reverse Camera Replacement Audi A3 8V Quote
Before I buy a new switchgear, I would still check the wiring, just to be safe. It actually looks like the switchgear is defective.
Viele GrĂŒĂŸe
Andreas
*** Ein Ingenieur muss vordenken. Wenn er anfÀngt nachzudenken ist es schon zu spÀt. ***
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L: CD Player Failure Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B: Intermittent GRA Failure Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A1 ABS/ESP Failure: No Brake System Access. Transmission, Chassis, Body & Interior
No new posts Reverse Camera Coding Q5 8R - No Image On-Board Diagnostics (OBD)
No new posts Golf 7 GTI: Install Reverse Camera (Aftermarket) On-Board Diagnostics (OBD)
No new posts Failure with Bora AJM Diesel Engine Technology
