Motor Speed Sensor & Control Unit Failure
Wurschdler
Post26-02-2020, 22:34    Subject: Motor Speed Sensor & Control Unit Failure Quote
Car: Volkswagen Golf 5 Variant, 1.9 TDI, 105 hp, 2008, mileage 187,000 km.
While overtaking on the highway at 80 km/h in heavy rain, the Golf's engine shut off and could not be restarted. The ADAC (German automobile club) had to tow the car to a workshop. The workshop checked the wiring to the G28 sensor and then offered to replace the sensor and rewire the cables for 500 euros.
I haven't had anything done yet because, for me, it's either a sensor signal or it's not. If G28 were defective, the engine wouldn't start.
Cables were only inspected in the visible area. The oil filter housing and its connection to connector G28 have not yet been disassembled.
Auto springt in Trockener Werkstatt wieder an und läuft jetzt wieder. Ersten Code Glühkerze ist bei altem km Stand. Fehler codes:
3 error codes found:
005660 - Spark plug, cylinder 3 (Q12)
P161C - 000 - Interruption.
Environmental conditions:
Error status: 01100000
Error priority: 3
Error frequency: 1.
Lost Count: 255
Mileage: 172,783 km
Time: 0.
Date: 2000.00.00
Time: 07:08:19
Speed: 819 RPM
Speed: 0.0 km/h
Last: 0.0%
Voltage: 14.06 V
Binary value: 00000100
Temperature: 14.4°C
Binary value: 10110000
000801 - Sensor for motor speed (G28).
P0321 - 000 - Implausible signal - Intermittent.
Error status: 00110000
Error priority: 1.
Error frequency: 1.
Lost Count: 255
Mileage: 187,233 km
Time: 0.
Date: 2000.00.00
Time: 07:57:18
Speed: 1764 RPM
Speed: 68.0 km/h
Last: 35.3%
Voltage: 14.29 V
Idle stabilization: 0.0° KW.
Speed: 1323 RPM
001542 - Control unit defective.
P0606 - 000 - CPU failure - Intermittent.
Error status: 00100000
Error priority: 2
Error frequency: 1.
Lost Count: 255
Mileage: 187,233 km
Time: 0.
Date: 2000.00.00
Time: 07:57:48
Speed: 5334 RPM
Speed: 71.0 km/h
Last: 0.0%
Voltage: 14.36 V
Hex Value: 0xFF00
Torque: 0.0 Nm
Readiness: 0 0 0 0 0
Log-187250km-1 nach g28.txt
 File name:  Log-187250km-1 nach g28.txt
 File size:  14.2 KB
 Downloaded:  450 times
 File size:  14.2 KB
 Downloaded:  416 times
Translated on 09-09-2026, 23:29.
Karma: +807 / -0   Thank you, like it!
Post27-02-2020, 10:09    Subject: Motor Speed Sensor & Control Unit Failure Quote
Since the issues with the sensor and the control unit occurred simultaneously, you should definitely check the wiring harness leading to the engine control unit for any defects. Also, make sure the engine control unit is dry and doesn't end up submerged in water during rain.
Translated on 09-09-2026, 23:35.
Wurschdler
Post27-02-2020, 18:16    Subject: Motor Speed Sensor & Control Unit Failure Quote
Thanks for the heads-up. I'll check it out over the weekend and get back to you.
Translated on 09-09-2026, 23:36.
Wurschdler
Post28-02-2020, 20:39    Subject: Motor Speed Sensor & Control Unit Failure Quote
The engine control unit was checked today. No abnormalities were found in the wiring, and the connectors are dry. The connectors were disconnected and inspected internally. They are in like-new condition. The next step is to remove the oil filter housing and check the connectors directly connected to the G28 sensor. I will replace the G28 sensor at the same time.
Today, with dry weather, I had no problems on an 80km highway drive.
 File size:  6.28 MB
 Viewed:  1490 times
Post01-03-2020, 15:28    Subject: Motor Speed Sensor & Control Unit Failure Quote
It might also be worth checking the larger fuses. I once had a situation with an A3 8L where a corroded fuse holder on the battery caused problems with the engine control unit (resulting in malfunctions in the vehicle's electrical system).
Translated on 09-09-2026, 23:37.
Wurschdler
Post07-03-2020, 20:34    Subject: Motor Speed Sensor & Control Unit Failure Quote
Hello, error found!
There was another error in the Autoscan:
Address: 08 Climate/Heating Department.
00898 - Control of air conditioning compressor. 010 - Open circuit/short circuit after positive terminal.
I then checked the connectors and found a loose connection at the air conditioning compressor.
This connector is located directly behind the engine fan, so moisture can easily get to the contacts when it's wet.
Thank you for the helpful tips in troubleshooting.
 File size:  4.11 MB
 Viewed:  725 times
 File name:  1583609857463.png
 File size:  1.26 MB
 Downloaded:  1718 times
Translated on 09-09-2026, 23:38.
Post08-03-2020, 11:39    Subject: Motor Speed Sensor & Control Unit Failure Quote
The loose connection may potentially cause other errors, but I'm not entirely sure that everything is now okay.
Water doesn't cause short circuits at 12V.
Translated on 09-09-2026, 23:39.
Wurschdler
dieselschrauber and Rüdi likes this.
Post23-05-2020, 9:04    Subject: Motor Speed Sensor & Control Unit Failure Quote
Update: It wasn't the climate control connector as initially suspected, but rather the contacts on the connector directly connected to the sensor. Since the car has been running perfectly since being towed from the workshop until today, I haven't contacted the workshop again.
The mechanic did more work than I was informed about. Specifically, while disconnecting the connector for the engine speed sensor (G28), he damaged the connector on the wiring harness side. This connector was replaced, and the contacts of both connectors were cleaned. According to the mechanic, the connector was likely already faulty, and over time, dirt and oil had accumulated on the contacts, causing the connection to deteriorate until it eventually failed. This explanation seems very plausible as the main cause.
I will continue driving without replacing the sensor, because if there were no previous issues, the likelihood is high that the problem has been resolved by cleaning and replacing the connector housing.
Translated on 09-09-2026, 23:40.
Post23-05-2020, 19:25    Subject: Motor Speed Sensor & Control Unit Failure Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Translated on 09-09-2026, 23:41.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty Control Unit or Sensor? On-Board Diagnostics (OBD)
No new posts Engine Speed Sensor | 00801 Diesel Engine Technology
No new posts VW Sharan Engine Speed Sensor (G28) Diesel Engine Technology
No new posts Touran 1.9 TDI 74kW, 2004, Engine Speed Sensor (G28) Diesel Engine Technology
