Tiguan 5N air conditioning system not working
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post04-07-2020, 10:00    Subject: Tiguan 5N air conditioning system not working Quote
Hello everyone,
I'm afraid I have to contact you about a curious climate-related issue.
The air conditioning system in the 2.0 TDI 140 hp Tiguan 5N (2010) is no longer working.
Please find attached the Autoscan report, as well as a picture of the climate control values that I believe are relevant, taken from the climate control unit.
The compressor seems to be running. At least, the internal "piston" is firmly engaged and everything is rotating. Also, it gets warm during operation. Both refrigerant lines leading to the evaporator remain equally warm. The small cooling fan also doesn't turn on when the AC is running. However, it can be successfully activated and runs at a high speed via the actuator diagnosis in the engine control unit. Therefore, I can rule out a mechanical defect.
I have the impression that the compressor is not working. Is there a way to verify this?
Thank you in advance for your help!
 File size:  6.91 MB
 Viewed:  2860 times
VCDS Auto-Scan Ausdruck-tiguan WVGZZZ5NZBW055592.pdf
 File name:  VCDS Auto-Scan Ausdruck-tiguan WVGZZZ5NZBW055592.pdf
 File size:  26.46 KB
 Downloaded:  895 times
Beste Grüße,
Hufe
Translated on 04-07-2026, 18:48.
Hufe
2004 Audi A6 Avant
dieselschrauber likes this.
Post04-07-2020, 22:30    Subject: Solution Quote
I wanted to edit the thread, but "Aunt Edit" (meaning the editing function) won't let me. Therefore, the solution to the puzzle from Saturday is being posted here for anyone who is interested.
The toothed wheel on the pulley's drive shaft is damaged. The retaining screw has sheared off. As a result, the drive shaft is spinning uselessly on the compressor's drive shaft, bypassing the overload protection. That's the situation. Good night, everyone.
 File size:  2.36 MB
 Viewed:  2001 times
Beste Grüße,
Hufe
Translated on 04-07-2026, 18:50.
Post05-07-2020, 9:06    Subject: Tiguan 5N air conditioning system not working Quote
Translated on 04-07-2026, 18:51.
No new posts A3 8P1 AC Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Van AC Repair: 7-Seater, No Cooling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3 8P1, Air conditioning not functioning, no ref... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken AC: Troubleshooting & Repair Tips Transmission, Chassis, Body & Interior
No new posts Manual AC Not Working? Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Tiguan 2020 - Discover Media without DAB... how is it set... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3 AC Not Working: 8P BKD Repair Guide Transmission, Chassis, Body & Interior
