Air conditioner -> Refrigerant pressure too high
Scout5e
Post15-08-2020, 20:34    Subject: Air conditioner -> Refrigerant pressure too high Quote
Hello everyone,
We're experiencing an issue with my wife's Fabia 3: the air conditioning system fails when the outside temperature is high (30 degrees Celsius or more).
The climate control unit will then store the following error code:
"1 error found:"
262913 - Refrigerant pressure too high.
B10AC F0 [012] - Unknown error description.
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 7
Lost Count: 151
Mileage: 45506 km
Date: 2020.07.30
Time: 14:03:05
Outside temperature: 31.5 °C
Motor speed: 1776 RPM.
Compressor current: Actual value: 0.360 A.
Temperature after evaporator: 10.9 °C
Refrigerant pressure: 32.2 bar.
System runtime: 222 seconds.
System runtime, terminal 15 active: 223 seconds.
Once the pressure drops again, the air conditioning system will start working again, and the error doesn't necessarily need to be explicitly cleared.
The initial thought was that there was too much refrigerant in the system. According to various tables online, there should be 500g +/- 25g. We emptied the system today, and it contained exactly 525g. They've now gone back to filling them with "only" 500g.
The second idea is a pressure sensor that occasionally malfunctions – is that realistic?
Today, on my way to the workshop, I briefly checked the system, and the refrigerant pressure was consistently between 10 and 16 bar. The temperature after the evaporator should be between 2 and 4 degrees Celsius, all while the outside temperature is approximately 24-26 degrees Celsius.
When connected to the air conditioning unit, it displayed the same pressure readings as the tester indicated.
My wife is understandably extremely frustrated with the situation, especially at this time of year, when the air conditioning should be working properly, especially for the sake of our two-year-old daughter.
I hope someone here can help me and/or give me a tip on what else I could check.
Best regards, Jochen.
brezelmann01
Karma: +75 / -0   Thank you, like it!
dieselschrauber and Rüdi likes this.
Post15-08-2020, 21:27    Subject: Air conditioner -> Refrigerant pressure too high Quote
Is the radiator fan running? Always? So, even if the system shuts down?
Karma: +591 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-08-2020, 21:57    Subject: Air conditioner -> Refrigerant pressure too high Quote
Hello!
It's been 10 years since I took a technical training course on air conditioning systems.
I don't have much practical experience myself.
What I still remember about it:
The pressure at steady state depends only on the temperature and the vapor pressure of the refrigerant.
As long as there is still some liquid refrigerant in the system, the system pressure remains the same, regardless of whether the system is fully charged or almost empty.
I can only advise you now.
to try and locate the air conditioner's dryer.
The part is located on the front passenger side, underneath the headlight.
This is a small aluminum container, about as thick as a Red Bull can, but half as tall.
is firmly embedded in the climate system.
If the air conditioner is running, please feel the dryer with your hand.
It should have a consistent temperature.
If one side is hot and the other side is cold, it should be replaced.
Background:
Moisture diffuses into the system through the rubber hoses of the air conditioning unit.
and the dryer contains granules that absorb moisture.
Eventually, it becomes saturated and actually gets clogged.
Perhaps that is the cause of the high pressure?
I'm not sure.
But that's the simplest thing you can do yourself, and it doesn't cost any money.
vag-driver
Post17-08-2020, 15:19    Subject: Re: Air conditioner -> Refrigerant pressure too high Quote
Scout5e wrote:
Hello everyone,
What is the temperature below 30°C? If the air conditioner is running, please check if the pipe before the expansion valve is frosted. Then the valve is likely defective, and the sensor may detect the increasing pressure and shut down.
Andreas
easytime
Post22-08-2020, 15:14    Subject: Fabia NJ air conditioning not working at high outside temperatures Quote
Hello.
"Our FABIA NJ has recently started experiencing the exact same issue with the system:"
"1 error found:"
Error priority: 2
Error frequency: 4
Lost Count: 171
Mileage: 53,351 km
Date: 2020.08.13
Time: 10:29:20
Outside temperature: 34.0 °C
Motor speed: 2607.25 RPM.
Compressor current: Actual value: 0.340 A.
Temperature after evaporator: 20.8 °C
System runtime: 11 seconds.
System runtime, terminal 15 active: 253 seconds.
I have the light sensor and the outdoor temperature sensor.
expanded and checked - both OK.
When the pressure drops again, the system works perfectly.
It would be interesting to know what caused the issue further up at Scout5e...
It would be interesting to know what happened during the...
easytime
Post22-08-2020, 15:16    Subject: Fabia NJ air conditioning not working at high outside temperatures Quote
The radiator fan only runs when the AC is turned on, but it doesn't cool down the car at all.
Post22-08-2020, 18:14    Subject: Air conditioner -> Refrigerant pressure too high Quote
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air conditioner smells bad General Tips
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Conditioner: Buy, Install & Repair Transmission, Chassis, Body & Interior
No new posts Air conditioner advice Transmission, Chassis, Body & Interior
No new posts Manual air conditioning Transmission, Chassis, Body & Interior
No new posts AC Smells Bad: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
