Ranug
Joined: 06/18/2020 Posts: 16 Karma: +2 / -0 Location: Lüneburg 2019 Skoda Octavia Premium Support
19-11-2022, 19:44 Subject: Fuel error Octavia |
Hello everyone,
I'm having a problem with my Octavia. According to VCDS, there's an issue with the fuel supply, but it doesn't happen all the time. Perhaps someone is familiar with this problem.
Sincerely,
Gunar.
| Description: |
 Download |
| File name: |
Log-LG-LZ 1509-TMBJR7NE2L0088867-44474km.txt |
| File size: |
24.13 KB |
| Downloaded: |
961 times |
Translated on 07-07-2026, 5:04.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18132 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
19-11-2022, 21:41 Subject: Fuel error Octavia |
There's probably a fuel pressure regulator; I'd check that and its wiring.
Why is the onboard voltage so low, at 11.x V? Is there a short circuit somewhere, a corroded wiring harness, or other issues with the power supply from the engine control unit?
Are there any other anomalies in the onboard voltage?
Does the engine reach its full power output for extended periods?
Translated on 07-07-2026, 5:05.
Profile PM WWW Garage |
