vag-driver Profi-Schrauber
dieselschrauber likes this. |
07-10-2020, 13:09 Subject: Polo 6N headliner sagging |
Unfortunately, after 23 years, gravity has also taken its toll on our roof. Are there any smart repair options available to fix it? I actually wanted to avoid having to dismantle it and have it reupholstered by a saddler. Viele Grüße
Andreas
Translated on 07-07-2026, 1:16.
Herbert Profi-Schrauber
07-10-2020, 13:47 Subject: Polo 6N headliner sagging |
No, it's probably the same here, as the structure is likely to be similar for the model years. Here's how it works:
/viewtopic.php?t=27606&highlight=himmel
Herbert. Horch A4 8K CJCD
Translated on 07-07-2026, 1:17.
07-10-2020, 21:29 Subject: Polo 6N headliner sagging |
I'm afraid I don't like the answer. I was afraid that would happen.
Where did you get this saddle soap? Viele Grüße
Andreas
07-10-2020, 22:07 Subject: Polo 6N headliner sagging |
IsoproQ
07-10-2020, 22:41 Subject: Polo 6N headliner sagging |
I need to take care of other projects first. Fortunately, the sky is only an illusion.
Thank you for the link. Viele Grüße
Andreas
Translated on 07-07-2026, 1:18.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
08-10-2020, 7:47 Subject: Polo 6N headliner sagging |
Perhaps it's best to look for a used one in good condition. For cars like the Polo 6N, you might still be able to find something like that for a relatively low price.
I only paid 50 euros for my old Touareg, but finding a similar premium car with electronic issues, a cracked dashboard, and a sagging headliner is much more difficult. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
08-10-2020, 8:20 Subject: Polo 6N headliner sagging |
Rüdi wrote: | Maybe just look for a working one; for consumer vehicles like the Polo 6N, you might still be able to find something like that for a relatively small amount of €
I even have one still in the basement. However, I don't want to have to deal with that issue again anytime soon, because the material is also deteriorating on this one. Then it's better to do it right once. Viele Grüße
Andreas
Translated on 07-07-2026, 1:19.
08-10-2020, 10:10 Subject: Polo 6N headliner sagging |
Translated on 07-07-2026, 1:20.
Profile PM Garage |
08-10-2020, 11:01 Subject: Polo 6N headliner sagging |
That really hurts me deeply. You invest time and money, but in the end, you're not satisfied with the result.
It's probably not going to be easy to create a "sky" that produces the desired result. Viele Grüße
Andreas
09-10-2020, 11:26 Subject: Polo 6N headliner sagging |
Olaf is a perfectionist, and the car he's building was already a rare item during his lifetime. You really should follow the whole story from the beginning to the present day. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
09-10-2020, 12:01 Subject: Polo 6N headliner sagging |
Quote: | | It is probably not that easy to cover a roof and achieve the desired result. |
I suspect the problem is that spray adhesive soaks into the fabric unevenly, creating different thicknesses of adhesive, which then looks bad when pressed together.
The adhesive sticks to itself, and depending on how much pressure is applied, it becomes thick or thin in that area.
Perhaps you could first spray the back of the material with a different type of adhesive, primer, or coating that would make it non-porous to adhesive, but would still allow the adhesive to bond to the surface?
The spray adhesive must not dissolve or penetrate the existing "coating".
This would eliminate the problem where different pressure on the upholstery material during adhesion, depending on the thickness of the material, becomes visible.
Translated on 07-07-2026, 1:21.
Profile PM WWW Garage |
dieselschrauber and Rüdi likes this. |
09-10-2020, 12:19 Subject: Polo 6N headliner sagging |
The molded part must be evenly and thinly coated with adhesive. For DIY projects, you can get decent results with a brush (which is how I did it). For a professional finish, use a spray gun like in the blog post linked above.
The adhesive must be allowed to air dry (finger test) so that it adheres to the fabric without soaking through it. Therefore, it doesn't make sense to treat the fabric itself with glue.
Spray adhesive from a can is unusable.
Translated on 07-07-2026, 1:23.
