Audi A6 4B - Instrument Cluster Replacement - Coding to Engine Control Unit
Maverrick
1999 Audi A4 Avant
Post01-11-2020, 23:48    Subject: Audi A6 4B - Instrument Cluster Replacement - Coding to Engine Control Unit Quote
Good evening, everyone.
For the past 5 years, I've owned VCDS, and so far, I've been able to solve every problem by searching here in the forum.
Ultimately, it finally happened, and I need your help. =)
I have an A6 4B model, manufactured in September 2000, with a 2.5 TDI engine and Quattro all-wheel drive.
Combination instrument, part number 4B0 920 432K.
A common issue: pixel errors in the FIS (Fault Information System).
I quickly bought a used combination instrument on eBay, thinking it was a bargain.
Used instrument cluster, part number 4B0 920 433G.
I've tried to integrate the new/used AI unit with my engine control unit, but unfortunately, it's not working.
I unlock the speedometer using the login code from the new/used instrument cluster (IC) and then attempt to pair the IC with the MSTG (Modular Scalable Telematics Gateway) using adaptation channel 50, using the login code of the MSTG.
He tells me, but as a result of system n.io...
Set the value back to 32000, and I'm back to the beginning.
Of course, I immediately wondered if the AI might not be compatible, but unfortunately, I haven't found anything conclusive online regarding a list that specifies which AIs are compatible with which models and which are not.
So, what am I doing wrong? "Has anyone else possibly experienced the same problem?"
Here are some more logs.
Code:
;SW:4B0-920-932-K   HW: ---  Schalttafeleinsatz --- SA: 03475
;Bauteil:C5-KOMBIINSTR. VDO D12 , Codierung:00060
;Freitag,16,Oktober,2020,23:30:28:56481
;VCDS Version: RKS 20.4.1  Datenstand: 20200709 DS317.0
;VCID: 2A0CF3C265E2E34B2DE-5160
Code:
;SW:4B0-920-933-G   HW: ---  Schalttafeleinsatz --- SA: 05478
;Bauteil:KOMBI+WEGFAHRS. VDO D12, Codierung:00060
;Samstag,17,Oktober,2020,12:15:17:56481
;VCID: 270A0AF676F0DE23320-5160
Code:
Sonntag,01,November,2020,21:08:30:56481
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: RKS 20.4.1.1  HEX-V2 CB: 0.4508.4
http://shop.dieselschrauber.org/en
Händler-/Werkstattname: Maverrick
Betriebsnummer: 123 12345 012345
Fahrzeug-Ident.-Nr.: WAUZZZ4B24N009320   KFZ-Kennzeichen:
Anpassung Kanalnummer 050:
Gespeich. Wert 32000
Getesteter Wert 32000
  warten
  n.v.
  n.v.
  n.v.
  System
  n.i.O.
  n.v.
  n.v.
  warten
  n.v.
  n.v.
  n.v.
Mave.
P.S.:
I've already tried various instructions.
Directly from Ross-Tech and self-created.
Of course, I've taken over the existing code and also rewritten parts of it myself, and I've tried all sorts of things.
No new posts Audi Key Fob Pairing: How To Guide Troubleshooting & Guides
No new posts Pairing VW radio keys Troubleshooting & Guides
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4: Park Heater Installation (2007) On-Board Diagnostics (OBD)
No new posts Faulty instrument cluster Audi A3 On-Board Diagnostics (OBD)
No new posts Audi A6 4F Avant Kombiinstrument, VAG-COM. On-Board Diagnostics (OBD)
No new posts Audi AEL: Noise after timing chain replacement Diesel Engine Technology
