Auxiliary Heater Unlock for Parking Heater
georgmech
Post26-01-2021, 12:32    Subject: Auxiliary Heater Unlock for Parking Heater Quote
Hello, I have a VW T6 here. I installed the Webasto wiring harness for upgrading to a parking heater, but unfortunately, I can't find the path to unlock it. I'm in the "parking heater" section, then "adjustment," and there are 20 adjustment channels, but none of them unlock the heater. Can anyone please help me? The engine code is CAH, 1968ccm, 110kW.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 17-10-2026, 22:09.
Back to top Profile PM Email
vag-driver
Post26-01-2021, 14:03    Subject: Auxiliary Heater Unlock for Parking Heater Quote
Without knowing for sure: the auxiliary heater will not be locked. Unless it has a malfunction.
Which retrofit kit do you use to control the SHZG? There has to be some way to control the SHZG.
Andreas
Translated on 17-10-2026, 22:10.
Post26-01-2021, 18:41    Subject: Auxiliary Heater Unlock for Parking Heater Quote
georgmech
dieselschrauber likes this.
Post03-02-2021, 9:41    Subject: Auxiliary Heater Unlock for Parking Heater Quote
Thanks very much, the auxiliary heater is now working. I had to unlock the control panel and I had programmed the wrong port in my laptop; it should be port 1, but it was set to port 5. The technician from the company fixed it for me using Teamviewer, and he was done in 2 minutes.
Thank you again for the great help.
Translated on 17-10-2026, 22:11.
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Heater Error 02085: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Heater Upgrade for Parking Heaters Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater Conversion to Stand Heater On-Board Diagnostics (OBD)
No new posts Auxiliary Heater for Audi A4 2.5 Qtip Transmission, Chassis, Body & Interior
No new posts VW Auxiliary Heater Not Working - Troubleshooting Transmission, Chassis, Body & Interior
