Thank you for the answers.
I had the driver's door open during the reading and clearing process, but I will try it again later with the doors closed.
If that was the reason why the error wasn't cleared, then that was a very helpful hint.
Okay, please provide the German text you want me to translate. I will provide the English translation without any explanations.
"Just a quick question: What more can be read from the entire scan compared to the essential part with the error message? I'm asking this to learn more about the OBD system."
Thursday, January 21, 2021, 11:50:09:24743
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 20.4.2.1 HEX-V2 CB: 0.4529.4
Data as of: 20201124 DS317.0
shop.dieselschrauber.org
Vehicle Identification Number: License Plate: RATT8N DIEZWEITE
Mileage: 166,840 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Mileage: 166,840 km
Address 01: Engine Control Module
Label file: DRV\06A-906-032-AJQ.clb
Part number: 8N0 906 018 BR
Component: 1.8L R4/5VT 0001
Encoding: 11500
Operating number: WSC 01236
VCID: 025C7F60CD191B6B446-5118
TRUZZZ8N141019308 AUZ5Z0CD035120
"One error found:"
16885 - Vehicle speed signal.
P0501 - 35-10 - Implausible signal - Intermittent.
Readiness: 0000 0000
Address 03: Brake Electronics Label file: DRV\8N0-907-379-MK60-F.lbl
Part number: 8N0 907 379 J
Component: ESP FRONT MK60 0101
Encoding: 0019469
Operating number: WSC 01236 785 00200
VCID: 43D2BA649783D2630F0-5118
No error codes found.
Address 08: Climate Control/Heating. Label file: DRV\8N0-820-043.lbl
Part number: 8N0 820 043 A
Component: TT CLIMATE CONTROL FULL AUTOMATIC SYSTEM D03.
Encoding: 00040
VCID: 28080DC80BE5113B3A2-2578
Address 15: Airbag
Label file: DRV\8N0-959-655.lbl
Part number: 8N0 959 655 D
Component: Front and Side Airbag 0000
Encoding: 01102
VCID: 41DEB06C889FC0731DC-5118
Address 17: Control panel module
Label file: DRV\8Nx-920-xxx-17.lbl
Part number: 8N1 920 930 Q
Component: COMBINATION INSTRUMENT + SPEEDOMETER. M73 D14
Coding: 00044
Operating number: WSC 76112
VCID: 3FDAB694FE6BB6836B8-4AE0
Address 35: Central Locking
Label file: DRV\8Nx-962-267.lbl
Part number: 8N7 962 267 D
VCID: 41DEB06C889FC0731DC-4EEA
or error codes are not supported by the control unit.
or communication errors occurred.
Address 55: Headlight range control. Label file: DRV\4B0-907-357-AUT.lbl
Part number: 4B0 907 357.
Component: LIGHT DIMMER D004
Coding: 00009
VCID: 659644FC3C77CC53C14-513C
Address 56: Radio
Label file: DRV\8E0-035-1xx-56.lbl
Part number: 4B0 035 186 S
Part: concert II GRO 0001
Encoding: 00200
VCID: 3038E5A8333559FBE22-4AE0
End--(Duration: 02:47, Battery Voltage Start/End: 11.8V/11.8V. VIgn 11.8V)---
