georgmech Schrauber
Joined: 09/10/2009 Posts: 69 Karma: +8 / -0 Location: Langenrohr
26-01-2021, 12:32 Subject: Auxiliary Heater Unlock for Parking Heater |
Hello, I have a VW T6 here. I installed the Webasto wiring harness for upgrading to a parking heater, but unfortunately, I can't find the path to unlock it. I'm in the "parking heater" section, then "adjustment," and there are 20 adjustment channels, but none of them unlock the heater. Can anyone please help me? The engine code is CAH, 1968ccm, 110kW.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 17-10-2026, 22:09.
Profile PM Email |
vag-driver Profi-Schrauber
26-01-2021, 14:03 Subject: Auxiliary Heater Unlock for Parking Heater |
Without knowing for sure: the auxiliary heater will not be locked. Unless it has a malfunction.
Which retrofit kit do you use to control the SHZG? There has to be some way to control the SHZG.
Andreas
Translated on 17-10-2026, 22:10.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
26-01-2021, 18:41 Subject: Auxiliary Heater Unlock for Parking Heater |
Profile PM WWW Garage |
georgmech Schrauber
dieselschrauber likes this. |
03-02-2021, 9:41 Subject: Auxiliary Heater Unlock for Parking Heater |
Thanks very much, the auxiliary heater is now working. I had to unlock the control panel and I had programmed the wrong port in my laptop; it should be port 1, but it was set to port 5. The technician from the company fixed it for me using Teamviewer, and he was done in 2 minutes.
Thank you again for the great help.
Translated on 17-10-2026, 22:11.
Profile PM Email |
