Error code P2177 - Lean condition system during idle (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Post06-03-2021, 12:37    Subject: Error code P2177 - Lean condition system during idle Quote
The error code P2177, Lean condition at idle, is detected by measuring the lambda sensor or the mass airflow sensor.
Identical Error Codes: 18609 / P2177 / 008567
Possible Causes:
- Insufficient fuel supply (leaks, clogged fuel injector, faulty fuel pump)
- Improper air intake (Leaks in the intake system)
- Leaks in the exhaust system before the lambda sensor
- Incorrect fuel pressure sensor (G247) installed
- Defect in the mass airflow sensor or its wiring (check the values for plausibility)
The error code P2177 refers to cylinder bank 1 of the engine, and error code P2179 indicates the same issue for cylinder bank 2.
Ratings - Error code P2177 - Lean condition system during idle
No new posts P2187 - Bank 1, System Too Lean (Idle) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2178 - Engine running too lean Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0171 Fuel System Bank 1 Lean Mixture Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehlercode 65535,Leerlauf ztw. nach dem Starten zu hoch On-Board Diagnostics (OBD)
No new posts A4 P0171 Fuel Trim System Too Lean Gasoline Engine Technology
No new posts Tried the PD-Powerbox -> performance gain is quite min... Diesel Engine Technology
No new posts TDI Tuningmaßnamen im System Diesel Engine Technology
