Passat B7 2.0 TDI 4motion Heater
B7rliner
Post02-05-2021, 17:32    Subject: Passat B7 2.0 TDI 4motion Heater Quote
Hi everyone,
I'm having the following problem. "In my Passat, only cold air comes out on the right side, and no air at all comes out on the left side."
Does anyone have any ideas or know where I can order something?
I've only heard that you don't have to remove the dashboard on the B7 model.
Best regards, Jan.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post02-05-2021, 18:05    Subject: Good evening Quote
Good evening, Jan,
Can you tell us a little more about the features?
What kind of air conditioning system do you have installed?
What does the error memory contain?
Various models experienced problems due to fluctuating on-board voltage, which resulted in the shutdown of air distribution, recirculation mode, and compressor control.
There is a software update available for this.
If it's not the software, the air distribution flaps might simply be stuck or defective. Or the wiring, or the control unit, or...
What's possible, or what's not possible? Does it only heat, or only cool, or does it only provide ventilation?
Michael.
No new posts P1118 - Oxygen Sensor Heater Circuit Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heated, auto-dimming side mirror malfunction General Tips
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Unlock XDS on a Passat B7 4motion 125kW (MJ12-kw22) Electrical Systems, Vehicle Electronics, Multimedia
No new posts VW Bora TDI 4Motion Upload
No new posts Golf 4 4Motion Stabilizer Bar Transmission, Chassis, Body & Interior
No new posts ESP Control Unit Coding - Golf 4 4motion TDI (AJM) On-Board Diagnostics (OBD)
