R5 PD BAC Combustion Interrupter and LLR at Full Capacity
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post15-06-2021, 12:14    Subject: R5 PD BAC Combustion Interrupter and LLR at Full Capacity Quote
Hello everyone!
I have a BMW R5 motorcycle for sale with a verifiable mileage of 160,000 km. It has an automatic transmission. No DPF.
Problem description: Intermittent misfires in cylinder 3, occurring sporadically at 790 RPM.
Idle speed control (cold) at +2.99 mg per injection on cylinder 3.
(warm at 1.xx)
All the other cylinders are within the specified range (-1 to icon_smile_thumb_up.gif).
When starting the R5 engine from cold, it runs noticeably unevenly and (presumably) on only 4 cylinders. The engine is shaking.
It improves as the engine speed increases, starting around 1200 RPM, or when the engine warms up.
Given that the PD values are okay when the engine is warm, I suspect there is a defect in the cylinder. Correct?
I suspect there might be damage to the piston rings, which could expand further with increasing temperature, leading to reduced cylinder compression. Alternatively, the cylinder bore itself (the "plasma" surface) might be damaged. (Previously, engine oil meeting specification 50700 was used.)
Are there any empirical data or insights on how long such a situation typically lasts? Since the entire block is affected, a repair or replacement would not be cost-effective given the year of manufacture (2003).
The performance is otherwise satisfactory. Acceleration and top speed are good.
Thank you very much.
Beste Grüße,
Hufe
Dagomanu
Karma: +55 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-06-2021, 23:24    Subject: R5 PD BAC Combustion Interrupter and LLR at Full Capacity Quote
Hello, the wrong oil (50700 instead of 50601) has unfortunately often been a problem with these engines and has caused many engine failures.
But first, I would definitely install a new PD unit (possibly a crossmember).
Best regards, Dago.
Post16-06-2021, 18:28    Subject: R5 PD BAC Combustion Interrupter and LLR at Full Capacity Quote
Hello.
First, remove the cylinder head cover and check if the actuation and adjustment of the relevant PD unit are correct.
alevuz
Karma: +32 / -0   Thank you, like it!
Post16-07-2021, 21:50    Subject: R5 PD BAC Combustion Interrupter and LLR at Full Capacity Quote
It could primarily be the PDE wiring harness... it's probably xx years old.
Does it make a "ticking" sound coming from the hood? --> Probably the NW (Northwest) or the hydraulic system is defective.
BAC in a Touareg? But it's actually Euro 4 with a DPF, so then it's 507.00(1).
BAC is not allowed in the T5 area - other owners.
Generally, if the engine is being pushed hard, it can sometimes cause a hole to burn in the pistons – especially if it's been chipped and tuned – which is often the case when you're driving on the Autobahn. "If it runs better when it's warm, even at idle, hmm, then things get interesting."
How does he start? Have you ever measured the fuel pressure?
"Cold being bad / warm being normal" doesn't really fit with the hole in the piston, in my opinion.
Take a look at the Hydros - I think I have something in mind regarding them...
SG
Manfred.
Lower the hood - Inspect the NW Hydros - Measure compression.
Touareg V10 TDI (AYH)
alevuz
Post17-07-2021, 11:42    Subject: R5 PD BAC Combustion Interrupter and LLR at Full Capacity Quote
Sure, here's the translation:
"Additional:"
Have you ever done a blow-by test?
The lid should not fly off when the engine is idling.
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Misfires on 2.0 TDI engine, rough running Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gasoline Engines, Audi, Model Year 2001, Combus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BKD 2.0 TDI A3 8P Verbrennungsaussetzer Diesel Engine Technology
No new posts AYL,Sharan VR6 Verbrennungsaussetzer auf Cyl.1,3,5 On-Board Diagnostics (OBD)
No new posts Golf IV, 1J, Injector, Combustion Failure On-Board Diagnostics (OBD)
No new posts Audi S4 B8, engine code CAKA, misfire P0303 Gasoline Engine Technology
