kickpanther
Joined: 12/26/2017 Posts: 10 Karma: +1 / -0 Location: Hannover
12-08-2021, 21:21 Subject: P0730: Incorrect Gear Ratio |
Hello fellow enthusiasts, I'm stuck on a problem and could use some help. Maybe you can point me in the right direction?
I would be happy.
I am encountering the following error:
17114 - Gear/Transmission Monitoring.
P0730 - 35-00 - Incorrect gear ratio.
Mileage: 295,000 km
I would be grateful for any tips.
| Description: |
 Download |
| File name: |
Passat 3B Systemscan.txt |
| File size: |
3.96 KB |
| Downloaded: |
575 times |
Vielen Dank.
Gruß Kickpanther
Translated on 20-10-2026, 15:40.
Ich_Can_nix Profi-Schrauber
dieselschrauber likes this. |
12-08-2021, 21:49 Subject: P0730: Incorrect Gear Ratio |
Good evening.
Do you also have an error image for that error entry? Does the transmission shift normally?
The error can have several causes.
It is usually caused by old, contaminated transmission fluid.
However, there may also be a mechanical fault in the transmission. Stuck or jammed solenoid valves are also possible.
Has the transmission ever been flushed?
Michael.
Translated on 20-10-2026, 15:41.
kickpanther
12-08-2021, 22:10 Subject: P0730: Incorrect Gear Ratio |
The transmission shifts very harshly and late when you put it in "D" (drive).
To my knowledge, a flush/rinse has not yet been performed.
Vielen Dank.
Gruß Kickpanther
Translated on 20-10-2026, 15:42.
vag-driver Profi-Schrauber
16-08-2021, 15:12 Subject: P0730: Incorrect Gear Ratio |
Then I would definitely perform at least one transmission fluid change. When was the last time it was changed?
Andreas
Translated on 20-10-2026, 15:43.
kickpanther
17-08-2021, 20:14 Subject: P0730: Incorrect Gear Ratio |
Unfortunately, there is no documentation available for this. We have owned the vehicle for approximately one year.
Best regards, Kickpanther.
Vielen Dank.
Gruß Kickpanther
matthiasTDI96 Profi-Schrauber
17-08-2021, 21:02 Subject: P0730: Incorrect Gear Ratio |
Okay, let's assume the worst. Why don't you do the oil change now? It can't hurt with a long-life oil system, and it's definitely the cheapest option. It's something you can easily do yourself, and then you can see what happens next.
