BMP 2.0 Shakes After Oil Pump Failure
Trogi
Post05-10-2021, 10:36    Subject: BMP 2.0 Shakes After Oil Pump Failure Quote
Hello.
I have what you might call a bucket without a bottom here. Since it's my son's Passat, I'm trying to salvage what I can.
Regarding the history:
The oil pump module failed, so my dear drove on with a trailer and a second car, uphill for about 4 km to the next exit. icon_peinlich.gif Without oil pressure.
Then we repaired the module, and the oil pressure is now present.
We replaced the turbocharger and are trying our luck again.
After approximately 500 km, the engine is losing power, and it's idling roughly.
Replaced the tandem pump, as it was no longer producing pressure.
Although the pressure is now correct, there's still no power and it's still sputtering.
PD elements were removed and sealing rings were replaced, but without success.
Boost pressure, compression (26 bar when cold), camshaft, tappets, and particulate filter have been checked and are in good condition.
The stopper in the rocker arm shaft was also missing, but it has been replaced.
Okay, so it starts well, and it runs smoothly when cold, but when it gets warm, it starts to idle roughly, and the overall performance is around 40 percent.
Here's another strange thing: The MWB 13 completely freezes when idling, and the fuel consumption display on the instrument cluster shows a ridiculously low value, for example, 2 liters per 100km in a 30km/h zone.
No error codes found.
I'm currently at my wit's end, maybe you can help me.
Best regards, Trogi.
Translated on 26-09-2026, 2:36.
Duese
Post05-10-2021, 12:34    Subject: BMP 2.0 Shakes After Oil Pump Failure Quote
Autoscan?
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Translated on 26-09-2026, 2:38.
Trogi
Post05-10-2021, 14:46    Subject: BMP 2.0 Shakes After Oil Pump Failure Quote
I will do that. Tomorrow.
Karma: +649 / -0   Thank you, like it!
dieselschrauber likes this.
Post12-10-2021, 5:09    Subject: BMP 2.0 Shakes After Oil Pump Failure Quote
Harness for PD (Power Distribution) components...
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CAYC rattles after EGR cooler replacement Diesel Engine Technology
No new posts Engine Misfire After Head Replacement - BKD Diesel Engine Technology
No new posts SQ5 is shaking Diesel Engine Technology
No new posts BMP is twitching Diesel Engine Technology
