Replacing the 8V particulate filter with the 16V catalytic converter on a 2.0 TDI PD
MrMcFly79
Post18-09-2021, 22:37    Subject: Replacing the 8V particulate filter with the 16V catalytic converter on a 2.0 TDI PD Quote
Hello everyone, has anyone ever done this conversion before? Does it probably require a lot of tinkering, or is it truly plug and play?
VG
Tobi.
3bAFN
Karma: +37 / -0   Thank you, like it!
dieselschrauber likes this.
Post19-09-2021, 9:00    Subject: Replacing the 8V particulate filter with the 16V catalytic converter on a 2.0 TDI PD Quote
What you're planning to do won't work without some adjustments.
Let's take the Passat 3C as an example.
There's the 8V BMP engine with a DPF (Diesel Particulate Filter), and the 16V BKP engine without a DPF, only with a catalytic converter. All particulate filter (DPF) systems installed at the factory are designed as closed systems and are therefore monitored by various sensors.
If you're now swapping your DPF for the catalytic converter, and it fits mechanically, you'll be missing all the sensors, and the engine control unit will immediately go into limp mode.
MrMcFly79
Post19-09-2021, 14:19    Subject: Replacing the 8V particulate filter with the 16V catalytic converter on a 2.0 TDI PD Quote
I will, of course, have that removed during a chip tuning process. icon_wink.gif
Sure, here's the translation:
"By the way, it's an A4 B7."
Post20-09-2021, 5:43    Subject: Replacing the 8V particulate filter with the 16V catalytic converter on a 2.0 TDI PD Quote
Then you know everything you need to do.
The proposed modification will inevitably result in the vehicle's operating permit being revoked, and we assume that it will never be used on public roads again afterward.
MrMcFly79
Post24-10-2021, 13:36    Subject: Replacing the 8V particulate filter with the 16V catalytic converter on a 2.0 TDI PD Quote
Okay, it's done, and it seems to be working fine so far without any issues.
He definitely has the temperature sensors before and after the particulate filter, and the oxygen sensor, stored in the error memory.
I haven't really thought about the oxygen sensor before. Is it just for monitoring the residual oxygen, or does it also control the air-fuel mixture? The 16V model doesn't have one, and apparently doesn't need it, which must have something to do with the particulate filter.
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Particulate Filter (DPF) VAG TDI Diesel Mass Balance, Max... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts Should I switch from AGM to EFB? Electrical Systems, Vehicle Electronics, Multimedia
No new posts MFA for FIS swap On-Board Diagnostics (OBD)
No new posts FIS exchange for a standard speedometer? Diesel Engine Technology
No new posts Exchange Old MFA/BC for New? Transmission, Chassis, Body & Interior
