Tiguan 12/2016, Towing Hitch Error
diddel
Post08-11-2021, 16:38    Subject: Tiguan 12/2016, Towing Hitch Error Quote
I have installed an AHK (trailer hitch) on a Tiguan R-Line, manufactured in December 2016, with a 2.0 TDI engine and DSG transmission.
The manufacturer is Westfalia, but while "Jäger" is printed on the power socket, "Trailtec" is printed on the control unit.
I still have some errors in a few control units.
Everything works on the trailer, except that when a trailer is attached to the vehicle, the rear fog light on the vehicle does not turn off.
Is my VCDS interface too old (HEX-USB+CAN)?
Sure, here's the translation:
"Thank you in advance."
Detlev.
Log-TIGUAN-WVGZZZ5NZHW860178-66319km.txt
 File name:  Log-TIGUAN-WVGZZZ5NZHW860178-66319km.txt
 File size:  20.02 KB
 Downloaded:  712 times
Translated on 08-07-2026, 17:10.
Post08-11-2021, 21:02    Subject: Tiguan 12/2016, Towing Hitch Error Quote
Hello Detlev,
Am Anhänger funktioniert alles, ausser dass am Fahrzeug die Nebelschluss nicht ausgeht wenn ein Anhänger am Fahrzeug angehängt ist.
In combination with the error "no communication with trailer control unit," I would strongly recommend checking the wiring again.
First, clear all the errors and see what comes back. Also, the issue with the tailgate control unit might be caused by incorrect wiring (which could be interfering with the CAN bus).
While the HEX-USB+CAN may not be able to detect all errors with all control units (there is a VCDS upgrade option), it should not matter for your specific situation.
Translated on 08-07-2026, 17:12.
Dagomanu
Karma: +55 / -0   Thank you, like it!
dieselschrauber likes this.
Post09-11-2021, 0:06    Subject: Tiguan 12/2016, Towing Hitch Error Quote
Hello, how did you perform the coding, or which control units did you code?
Best regards, Dago.
Translated on 08-07-2026, 17:13.
diddel
Post09-11-2021, 17:05    Subject: Tiguan 12/2016, Towing Hitch Error Quote
Hello Dago,
I can't look inside the multifunction control unit.
I saw in some videos that the rear fog light was specifically coded to 09.
Okay, I've checked all the control units so far, except for the (multi-) one.
and 4B and CF.
I need to check all the cables again, and I think I'm going to upgrade the interface.
Dagomanu
Post10-11-2021, 0:40    Subject: Tiguan 12/2016, Towing Hitch Error Quote
I suspect the rear fog light isn't switching because the vehicle or the module being programmed doesn't recognize a trailer. Have you registered the trailer hitch as installed in coding channel 0019? It's possible that you need to change "Connection of trailer socket" to "installed" in adaptation channel 0009 (login 31347). (I'm not sure if this applies to this vehicle, so it's always a good idea to save all previous codings as a precaution.)
You'll almost certainly need to code the lane change assist feature; I don't think it's controlled by the multifunction control unit.
But first, as already mentioned, check the wiring. It's very easy to overlook something.
Best regards, Dago.
Translated on 08-07-2026, 17:14.
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resetting the inspection service on a 2016 Tiguan using VCDS On-Board Diagnostics (OBD)
No new posts Audi A3: Syncing Key Fob (8V 2016) On-Board Diagnostics (OBD)
No new posts 1.4 TSI CZDA (2016) P0300 / P0301..04 Gasoline Engine Technology
No new posts Ford Transit, manufactured in 2016, battery replacement Electrical Systems, Vehicle Electronics, Multimedia
