Audi A6 C6 battery coding
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vag-driver
Post01-11-2021, 11:48    Subject: Audi A6 C6 battery coding Quote
The Audi still had the original Varta battery from 2007 installed. I replaced it with a more powerful Banner battery and wanted to code the new values into control module STG. 61. However, this works differently here than I'm used to from newer VW vehicles.
The Audi has a start/stop system and also a pre-heating function.
Andreas
chli1976
Karma: +185 / -0   Thank you, like it!
dieselschrauber likes this.
Post01-11-2021, 12:29    Subject: Audi A6 C6 battery coding Quote
It should be described in VCDS how you need to do it.
VCDS
vag-driver
Post01-11-2021, 12:44    Subject: Audi A6 C6 battery coding Quote
Unfortunately, I didn't take any screenshots...
In the STG 61 coding menu, there's a drop-down menu where you can select the old ET number of the battery. After that, a long string of code appears, which is not further documented. Is this the BEM code of the new battery? Or what should I put here?
Simply specifying the new manufacturer and incrementing the serial number by one probably won't be enough, because I want to inform the STG (System Test Group) that the new battery has 50A more cooling capacity.
Andreas
chli1976
Post01-11-2021, 14:56    Subject: Audi A6 C6 battery coding Quote
"That won't work, or you'll need to find a part number that specifies the specifications of your new battery." Increase the serial number by 1, and you won't be able to do anything else.
VCDS
vag-driver
Post01-11-2021, 15:37    Subject: Audi A6 C6 battery coding Quote
chli1976 wrote:
That won't work, or you'll need to find a part number that matches the specifications of your new battery. Increase the serial number by 1, and you won't be able to do anything else
Increasing the serial number and specifying a new manufacturer won't achieve anything.
Andreas
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber and Herbert likes this.
Post07-11-2021, 14:31    Subject: Audi A6 C6 battery coding Quote
Hello...
1. You can select the manufacturer from the dropdown menu.
2. Enter the part number (that matches the specifications of your battery).
>> This allows you to specify the Ah (ampere-hour) capacity of your battery to the BEM (Battery Energy Management) system, as well as the battery technology being used (standard flooded or AGM).
It determines the charging curve, the final charging voltage, and the amount of energy that can be extracted.
This is important so that the deep discharge protection kicks in on time and the display in the MMI is accurate.
3. Change the serial number. This will reset all learning values (battery aging and the counter for charging cycles used).
Otherwise, the "new" one will be loaded just like the "old" one, with the same high level of wear and tear.
- AGM batteries with capacities of 95Ah and 105Ah are possible.
- For wet batteries, a maximum of 110Ah is possible; higher capacities will not be recognized.
Regards, Mpire.
vag-driver
dieselschrauber and Mpire likes this.
Post07-11-2021, 21:04    Subject: Audi A6 C6 battery coding Quote
The new Banner battery has a slightly higher cold-cranking current but the same capacity of 110 Ah. This means that I select "Banner" from the drop-down menu and increment the serial number by 1. This will then reset the values in the Battery Management System (BMS). As soon as the Audi is back with me, I'll take care of it.
Andreas
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Drain: Audi A2 8Z0 MJ 2002 Doc Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding the second battery? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi C4 Klimabediengerät codieren On-Board Diagnostics (OBD)
No new posts Audi Q7 Batterie sporadisch entladen Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi TT: Can't code central locking control unit. Help On-Board Diagnostics (OBD)
