Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. *
jan__1104
2007 Audi A4 Avant
Post17-11-2021, 10:05    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
Hey tinkerers,
I have a question. The timing chain (specifically, the "Trieb B" component) broke at 156,000 km, and I didn't notice it. I thought it was a problem with the fuel pump. However, after I realized it was the timing chain, I tried to start the engine a few more times. As a result, it had wrapped itself around the drive D and had therefore flown apart into pieces.
My first question is, is it still worth switching? And if so, how does one adjust the timing chain?
My second question is whether the valves have been affected in any way. (According to my opinion, no, because there was no camshaft running alone.) Since one side has the vacuum pump running and the other has the HD pump.
VEHICLE:
Brand: Audi
Art : Avant
Model: A4 B7 (8ED)
Year of Manufacture: 2007
Engine Code: ASB
 File size:  200.73 KB
 Viewed:  3771 times
Herbert likes this.
Post17-11-2021, 21:59    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
Unfortunately, it's the case that in every position of the camshaft, there is at least one cylinder with open valves.
When the crankshaft then makes one revolution, it will definitely make a noise.
Hi, Rainer
dieselschrauber and Herbert likes this.
Post18-11-2021, 8:31    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
Honestly, I don't think it's worth it. Just remove the affected part and check the valves; there's probably one that's out of contact. If, against all odds, everything is okay, you can figure out the chain issue then. They should all be replaced. There must be a comprehensive repair manual from Erwin* that answers all questions.
I am, however, honestly concerned that at 14 years of age, the individual player's value must be higher than the current market value in order to achieve this.
Post22-11-2021, 6:56    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
ASB --> Gasoline engine?
If so, organize a used engine, replace everything, and install it. This would be my option, provided the A4 isn't taken away from the previous Opel owner soon.
vag-driver
Post22-11-2021, 14:38    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
ASB is the V6 diesel.
Andreas
jan__1104
2007 Audi A4 Avant
Post23-11-2021, 21:53    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
Remove the right cylinder head. (viewed from the front)
The 1.2 cylinder looks good. The 3 has attached
therefore, the levers above are broken but the valves are
look good so far.
Regarding the timing chain:
Shafts B and D have broken and need to be replaced.
Axles A and C still look good.
2 gears are misaligned and one gear has missing teeth.
I'm really amazed that it still looks so good!
PS: I've read that the right timing chain is prone to breaking.
and that's why Audi designed the engine so that you can
the right side in the closed state is interchangeable
is. And thus, the right side is much more robust and
Designed for durability, so that it can withstand such things.
can hold.
Best regards
Jan Pohl
 File size:  609.16 KB
 Viewed:  993 times
 File size:  492.52 KB
 Viewed:  1155 times
 File size:  448.47 KB
 Viewed:  671 times
vag-driver
dieselschrauber likes this.
Post23-11-2021, 22:56    Subject: What is your plan? Quote
What is your plan?
Andreas
Post23-11-2021, 23:11    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
can hold.
Jan Pohl
Therefore, the connecting rods on this side are also thicker, the camshafts are stronger, and the pistons and connecting rods are also reinforced. For example, you can tell this by the heavier cylinder head and the different balance shafts.
If you're lucky, the crank mechanism and two pistons are still usable.
jan__1104
2007 Audi A4 Avant
Post24-11-2021, 7:24    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
Get the engine running again.
1. The cylinders look good to me and I will keep them as is.
2. Cylinder head also looks good. "I will remove the valves from the 3rd cylinder and measure them to check if they are still straight."
If so, are there new chains with gears, new levers, and a new clutch because if it's already disassembled.
Post24-11-2021, 11:29    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
Even if the valves look good, it's important to remove them and inspect them, as they can be compressed, and this is not apparent when they are installed.
I would also thoroughly disassemble everything, meticulously clean all parts, and re-machine the valves. I always do this when a TDI head needs to be removed. New valve stem seals are, of course, a standard procedure.
jan__1104
2007 Audi A4 Avant
Post23-12-2021, 23:15    Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY **Tools Required:** * New Timing Belt * New Water Pump (recommended) * New Tensioner Pulley (recommended) * Timing Belt Tension Gauge * Socket Set * Wrench Set * Torque Wrench * Pliers * Screwdrivers * Jack and Jack Stands * Drain Pan * Coolant * Timing Belt Alignment Tool (optional, but highly recommended) **Safety Precautions:** * Disconnect the negative battery terminal before starting any work. * Work in a well-ventilated area. * Wear safety glasses and gloves. * Dispose of used coolant properly. **Procedure:** 1. **Preparation:** * Park the vehicle on a level surface. * Allow the engine to cool completely. * Disconnect the negative battery terminal. * Drain the coolant from the radiator and engine block. 2. **Removal:** * Remove the accessory belts (alternator, power steering, A/C). * Remove the drive belts. * Quote
Hi, I've now checked everything.
3 valves were misaligned, I replaced them and went to sleep.
The rest looked great.
Now I can't find anywhere that shows or explains how to properly assemble, tension, and adjust a chain tensioner.
Neither on the web nor in ELSA
Best regards
Jan Pohl
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace Fuel Injectors: DIY Guide & Tips Diesel Engine Technology
No new posts Audi A6 3.0 TDI Timing Chain Replacement Diesel Engine Technology
No new posts Audi 80 - Replacing the Heater Core Upload
No new posts Audi A3 8P: Replace Body Control Module? On-Board Diagnostics (OBD)
