stkfz Guest
23-04-2020, 12:52 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Hello diesel enthusiasts,
ich ärgere mich hier mit einem Touareg aus 2006 herum. Engine is BKS.
The vehicle has had a 'reconditioned' DPF installed for some time now (the customer took care of this). Since then, the error code P242F keeps appearing, and the car is going into limp mode.
I've had good luck with ash mass balance matching in the past, but unfortunately, it doesn't seem to work with the BKS system.
If I understand correctly, adaptation K.81 simply resets everything to zero (new OE filter), and K82 is unclear to me. It seems intended for adapting an old DPF to a potentially replaced engine control unit (ECU). Could this be used to circumvent something?
Ramon.
Translated on 30-07-2026, 6:01.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
24-04-2020, 9:09 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Hello Ramon,
It should be customizable, please post an Autoscan.
Problems like the ones you're describing should not occur when the DPF is "empty" rather than "full." It's possible that the DPF regeneration process is being initiated too frequently, but that's likely the only issue.
"Error code P242F, in my opinion, indicates that the DPF is clogged. Let's see what the car scan shows."
Does the AGR system function correctly? Does the engine not require oil and avoid oil dilution issues? Is the turbocharger intercooler system leak-free? Are all temperature sensors on the DPF (Diesel Particulate Filter) functional and properly connected?
See also:
DPF not regenerating
Translated on 30-07-2026, 6:03.
Profile PM WWW Garage |
chli1976 Profi-Schrauber
dieselschrauber likes this. |
25-04-2020, 10:13 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Normally, it's adaptation channel 12, but it should be specified in VCDS.
When a DPF (Diesel Particulate Filter) has been regenerated or cleaned, the ash mass should be reset to as close to zero as possible; otherwise, problems may occur.
VCDS
Translated on 30-07-2026, 6:04.
stkfz Guest
27-04-2020, 7:44 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Hello Rainer,
'Please provide the Autoscan data as soon as possible. The error reappears within seconds, and regeneration cycles are not completing. Oil dilution was noticeable, but the oil has now been changed. Temperatures and other parameters appear to be reasonable.'
It's noticeable that the car has a pungent exhaust smell and sometimes produces smoke. Injector for cylinder 1 was clearly faulty (diagnostic code 72) and has already been replaced.
@chili1976: Unfortunately, this motor only goes to 0 or doesn't work at all.
Translated on 30-07-2026, 6:05.
stkfz Guest
27-04-2020, 11:31 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Monday, April 27, 2020, 12:23:53:06130
VCDS - A VAG/VAS emulator based on Windows, running on Windows XP x86.
VCDS version: RKS 18.2.1.0
Data as of: 20180904 DS287.4
http://shop.dieselschrauber.org/en
Vehicle Identification Number (VIN): WVGZZZ7LZ7D010787 License plate:
Mileage: 272470 km. Repair order:
'Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang.'
Vehicle type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Vehicle Identification Number (VIN): WVGZZZ7LZ7D010787. Mileage: 272,470 km.
'Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag.'
'The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day.'
Address 01: Engine Control Module
Label file: DRV\059-907-401-ASB.clb
Part number SW: 7L0 907 401 B HW:
Part: 3.0L V6 TDI, part number G000AG, code 0080.
Revision: --H03--- Serial Number: VWZ3Z0F1503598
Encoding: 0011775
Operating number: WSC 11111 111 11111
VCID: 2A5D7E5586E8DB145F-5160
'One error found:'
009263 - Diesel particulate filter.
P242F - 001 - Maximum load exceeded - Warning light ON.
Environmental conditions:
Error status: 11100001
Error priority: 0
Error frequency: 1.
Lost Count: 255
Mileage: 272475 km
Time: 0.
Speed: 756 RPM.
(no unit): 65.8
(no unit): 54.0
(no unit): 27.5
Temperature: 112.1°C
Pressure: 0.0 mbar.
Pressure: 0 mbar.
Readiness: 1 1 0 0 0
Address 02: Transmission Label file: DRV\09D-927-750.clb
Part number: 09D 927 750 EB
Component: AL 750 6A 0879
Coding: 0004200
Operating number: WSC 31414 000 00000
VCID: 72EDA6356EB8D3D427-5160
No error codes found.
Address 03: Brake Electronics
Label file: 7L0-907-379-MK25.lbl
Part number: 7L0 907 379 G
Part: ESP All-Wheel Drive Module MK25 0203.
Encoding: 0014594
Operating number: WSC 31414 790 00001
VCID: 3D77450967665CAC0A-5160
'One error found:'
00778 - Steering angle sensor (G85).
000 - - - Sporadic
Address 05: Access/Startup. Label file: DRV\3D0-909-13x-05.lbl
Part number SW: 3D0 909 139, HW: 5WK 484 94.
Component: Kessy 6700
Revision: 67006015 Serial Number: VWZ3Z0F1503598
Encoding: 0000232
VCID: 66C5CA6552703F74BB-5160
Subsystem 1 - Part number: XXXXXXXXXXX
Component: Low Voltage (ELV) XXXX
Two error codes found:
00668 - Voltage at terminal 30.
009 - Intermittent short circuit to ground.
00087 - Terminal 30 for consumers relevant to starting.
Address 08: Climate Control/Heating. Label file: DRV\7L6-907-040.clb.
Part number: 7L6 907 040 T
Component: CLIMAtronic R/L 4222
Encoding: 0000230
VCID: 418F39F91B9E384C6E-5160
6 error codes found:
02101 - Actuator motor for side intake (V262).
text
000 - -
00657 - Actuator for center outlet (V102).
000 - - - Sporadic
00710 - Actuator motor for defrost flap (V107).
005 - No or incorrect initial setup/adjustment.
00709 - Photosensor 2 for sunlight detection (G134).
01592 - Air quality sensor (G238)
014 - defective
01207 - Control unit for auxiliary heater (J364).
004 - No signal/communication - Intermittent.
Address 09: Central Electronics; Label file: .DRV\7Lx-937-049-V1.clb
Part number: 7L6 937 049 M
Component: 3002
Encoding: 0122108
VCID: 46852AE532B01F745B-5160
3 error codes found:
01117 - Load signal for generator terminal DF.
008 - implausible signal - sporadic.
00907 - Load management procedure.
text
000 - -
01520 - Rain and light sensor (G397).
Address 15: Airbag
Label file: DRV\3D0-909-601.lbl
Part number: 3D0 909 601 F
Part number: 0C Airbag 8.4E+ H11 1151
Coding: 0012355
VCID: 26458A6592F0FF747B-5160
'One error found:'
00532 - Power supply voltage.
002 - Lower limit exceeded - Intermittent.
Address 16: Steering wheel electronics
Label file: DRV\7L6-953-549.lbl
Part number: 7L6 953 549 H
Component: Steering column module 3401.
Encoding: 0010031
VCID: 448130ED048C2D6445-5160
Address 17: Control panel module
Label file: DRV\7L6-920-xxx-7LA.lbl
Part number: 7L6 920 881 S
Component: COMBINATION INSTRUMENT RB8 3211
Encoding: 0007111
VCID: 489924DD38A40904A9-5160
01315 - Transmission control unit.
02751 - Control unit for cornering light and headlight range adjustment (J745).
Address 18: Auxiliary heater
Label file: DRV\7L6-819-008.clb
Part number: 7L6 819 008 D
Component: Auxiliary heater E1MAC
Encoding: 0000000
Operating number: WSC 62286 123 85454
VCID: 377B5721455A76FCD0-5160
'One error found:'
01126 - Engine speed signal.
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0101
Encoding: 0000006
VCID: 70E9AC3D60B4E1C4D1-5160
Address 1C: Vehicle status encoder. Label file: 7L6-919-879.lbl
Part number: 7L6 919 879 A
Component: JCI PathPoint 2200.
Operating Number: WSC 00000 000 00000
VCID: 45872DE90FB6146C52-5160
Address 22: All-wheel drive
Label file: DRV\0AD-927-755.lbl
Part number: 0AD 927 755 BE
Component: TRANSFER CASE 0122
VCID: 7F0B7F012DEA8EBC58-5160
Address 34: Level Control
Label file: DRV\7Lx-907-553-34.clb
Part number: 7L0 907 553 H
Component: AIR FILTER - CDC - 3C3P1 3099
Encoding: 0015521
VCID: 3879541D48447984D9-5160
Address 36: Seat adjustment for driver. Label file: None.
Part number: 7L0 959 760.
Component: Seat adjustment 0702
VCID: 77FB972105DAB6FC10-5160
'One error found:'
Address 37: Navigation
Label file: DRV\7L6-919-887-DVD.lbl
Part number: 7L6 919 887 H
Component: Navigation 0028
Encoding: 0000101
VCID: 4B931BD129D2E21C84-5160
Address 46: Comfort System
Label file: 7L0-959-933.lbl
Part number: 7L0 959 933 H
Component: YP HSG 0400
Encoding: 0000085
Operating number: WSC 50008 123 91024
VCID: 418F39F91B9E384C6E-4B20
Subsystem 1 - Part number: 7L0 959 701 G
Component: Door control unit FS 0201.
Subsystem 2 - Part number: 7L0 959 702 G
Component: Door control unit BF 0201.
Subsystem 3 - Part number: 7L6 959 703.
Component: Door control unit HL 0202.
Subsystem 4 - Part number: 7L6 959 704.
Component: Door control unit HR 0202.
00930 - Rear left central locking control unit (F222).
Address 55: Headlight range control. Label file: 7L6-907-357.lbl
Part number SW: 7L6 907 357, HW: 7L6 907 357.
Component: AFS Control Unit 0003
Revision: H09 Serial Number:
Encoding: 0000003
VCID: 78F9941D08C4B98419-5160
Subsystem 1 - Part number: 7L6 941 329
Label file: 3D0-941-329.CLB
Component: AFS-List Module l X018
Encoding: 00000034
Subsystem 2 - Part number: 7L6 941 330.
Component: AFS-List Module r X018
Encoding: 00000034
Address 56: Radio
Label file: DRV\7L6-035-186-DVD.lbl
Part number: 7L6 035 186 D
Component: Radio 0028
Encoding: 0016452
VCID: 3461602D542C9DE4F5-5160
Address 68: Wiper electronics
Label file: 7L0-955-119-V2.clb
Part number: 7L0 955 119 K
Component: Front Wiper - Part Number: 4027
Coding: 0000341
Operating number: WSC 31414 000 376832.
VCID: 3C71480D7C7C55A43D-5160
Subsystem 2 - Part number: 1K0 955 559 AE
Label file: DRV\1K0-955-559-AF.CLB
Component: RLS 180606 014 1201
Encoding: 00208933
Address 6D: Rear door
Label file: DRV\7L6-959-107.clb
Part number SW: 7L6 959 107, HW: 7L6 959 107.
Part: J605 TAILGATE 1110
Revision: --H05--- Serial number: --------003822
Encoding: 0022110
Address 6E: Number of/beds in attic room. Label file: None.
Part number: 7L6 919 044 S
Component: ROOF DISPLAY 0539
Revision: 00900539 Serial Number: 2009266.07
VCID: 479B27E135BA067CA0-5160
Address 76: Parking Assist
Label file: Route deviation detected!
Part number: 7L0 919 283 F
Part number: 0E Parking Assist System, 1107.
VCID: 397F5119734E608C26-5160
'One error found:'
00435 - Parking assist sensor, front right inner (G333).
006 - Short circuit to positive terminal - Intermittent.
Address 77: Telephone Label file: DRV\7L6-035-729-9ZA.lbl
Part number SW: 7L6 035 729 H, HW: 7L6 035 729 H.
Component: FSE_275x H21 0030
Revision: 00000001 Serial Number: 00000000482214
Encoding: 0000311
VCID: 3B734B117972529C34-5160
End----------------------------(Duration: 08:55)-----------------------------
| Description: |
 Download |
| File name: |
Log-WVGZZZ7LZ7D010787-272470km.txt |
| File size: |
12.92 KB |
| Downloaded: |
532 times |
Translated on 30-07-2026, 6:44.
27-04-2020, 17:59 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Hi.
Error priority: 0
Error frequency: 1.
Lost Count: 255
Mileage: 272475 km
Time indication: 0 |
If not already done, perform the initialization of the particulate filter in the adaptation channels of the engine control unit, and if possible, reset the learned values.
Removing and cleaning a diesel particulate filter (DPF)
After that, try to initiate a forced regeneration, and if successful, record the differential pressure at the DPF and compare those values with the ones discussed in this forum.
At the top of this forum, there's a topic with comparison values related to that.
Translated on 30-07-2026, 6:46.
stkfz Guest
28-04-2020, 7:05 Subject: Adjustable Oil Ash Volume for BKS Filters? |
'Of course, it was initialized. I suspect that's the problem here. I think the DPF has too much back pressure for a 'new' filter, which doesn't match the expected performance curve, and that's why we're getting the P242F error code.'
A forced regeneration is currently not being completed. Unfortunately, I cannot make sense of the termination conditions.
I will still try again later.
Translated on 30-07-2026, 6:48.
Herbert Profi-Schrauber
28-04-2020, 8:03 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Hi there,
Please provide us with the shutdown conditions and show us the current values for soot and ash loading, as well as the limits for field and service regeneration.
Translated on 30-07-2026, 6:49.
stkfz Guest
29-04-2020, 12:56 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Okay, here are the logs for MWB 101, 102, and 104 during the forced regeneration process.
Also, a photo is also needed for release/termination conditions, soot buildup, etc.
I am currently unable to use Scope because I don't have access to my email address or login credentials. However, I am working on resolving this issue.
| Description: |
| File size: |
1.08 MB |
| Viewed: |
931 times |
| Description: |
 Download |
| File name: |
LOG-01-101-102-104.CSV |
| File size: |
147.91 KB |
| Downloaded: |
345 times |
Translated on 30-07-2026, 6:50.
29-04-2020, 18:01 Subject: Adjustable Oil Ash Volume for BKS Filters? |
899°C is too hot... for example, in the BRE motor, it was regulated down starting at 820°C.
If he's not fully recovered, just try again.
Translated on 30-07-2026, 6:51.
stkfz
30-04-2020, 7:39 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Something happened with my account here... I had to register again.
The "899 degrees" reading also caught my attention, but I've come to the conclusion that this parameter likely has no effect, as there is no sensor for that temperature on the car. There are only sensors for turbocharger temperature and pre-DPF (Diesel Particulate Filter) temperature. These two values are present and within acceptable ranges.
What do you think about the differential pressure values? I don't find them to be unusually high. The ash content is at 0, and the sulfur entry is below the limit values. Why is it even reporting an error?
I have already tried several regenerations.
Translated on 30-07-2026, 6:52.
30-04-2020, 11:50 Subject: Adjustable Oil Ash Volume for BKS Filters? |
stkfz wrote: | | Something happened to my account here... I re-registered. |
Forum emails sent to your email address were returned as undeliverable. I then assumed the problem was due to outdated login credentials.
Either there's too much oil in the DPF, which explains the high temperature and possibly the failure of the regeneration process.
Find out why it's not regenerating.
Or maybe the temperature sensor is faulty... you can check the readings to see what other values it's displaying.
Normally, at idle, the temperature is between 100-200°C.
It might be worth trying to drive with the DPF temporarily removed (be careful that nothing falls off), but the engine should not produce excessive smoke or black exhaust.
Translated on 30-07-2026, 6:54.
stkfz
30-04-2020, 12:36 Subject: Adjustable Oil Ash Volume for BKS Filters? |
This parameter always displays 899 degrees, even when the vehicle is ice cold, but there is no corresponding sensor reading. There is only one sensor on the turbocharger and one on the DPF inlet. These sensors are also behaving realistically (see log).
Translated on 30-07-2026, 6:55.
stkfz
30-04-2020, 12:59 Subject: Adjustable Oil Ash Volume for BKS Filters? |
"Once, the exhaust gas temperature, and once, the differential pressure profile."
| Description: |
| File size: |
134.69 KB |
| Viewed: |
518 times |
| Description: |
| File size: |
162.9 KB |
| Viewed: |
504 times |
Translated on 30-07-2026, 6:56.
01-05-2020, 11:19 Subject: Adjustable Oil Ash Volume for BKS Filters? |
Quote: | | This parameter always shows 899 degrees, even when the vehicle is ice cold, but there is also no affected sensor reading. There is only one sensor on the turbo and one on the DPF inlet. These sensors behave realistically (see log) |
Is the engine control unit (ECU) software genuine?
stkfz
03-05-2020, 17:02 Subject: Adjustable Oil Ash Volume for BKS Filters? |
I don't really have any reason to believe otherwise. The car has been with the customer for many years, and definitely nothing has been changed.
Is that verifiable?
Translated on 30-07-2026, 6:57.
