hkss Blaumann
Joined: 12/17/2006 Posts: 171 Karma: +13 / -0 Location: Karlsruhe 2017 Skoda Yeti Premium Support
19-03-2017, 21:17 Subject: Plug next to battery terminals - function? |
"What component/function is this connector next to the battery terminal for?"
For me, it's a Skoda Yeti from 2017, while for my acquaintance, it's a Seat Leon from 2016.
I suspect that even more models from the Volkswagen Group have this part installed.
| Description: |
| File size: |
265.24 KB |
| Viewed: |
5761 times |
Profile PM Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
dieselschrauber likes this. |
19-03-2017, 22:46 Subject: Plug next to battery terminals - function? |
Evening.
I would argue that this is related to battery management.
Profile PM Garage |
Coldrule
Joined: 10/19/2016 Posts: 4 Karma: +0 / -0 Location: Austria 2001 Volkswagen Golf  Free account, no CAN development support
05-04-2017, 20:53 Subject: Plug next to battery terminals - function? |
If the component is connected to the pulse pole (or is part of the terminal), it is definitely the battery sensor.
Golf IV Variant 1.9 TDI
MKB:ALH
GKB:EGR
Profile PM Garage |
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
07-04-2017, 18:33 Subject: Plug next to battery terminals - function? |
Coldrule wrote: | | If the component is connected to the pulse pole (or is part of the terminal), it is definitely the battery sensor. |
Wrong! The battery sensor is located in the main power cable.
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
08-04-2017, 15:54 Subject: Plug next to battery terminals - function? |
brezelmann01 wrote: | | ...Wrong! The battery sensor is located in the chassis ground wire. |
Sure?
We have tested both the Hella parts (12V and 24V versions) and the old ISA ASIC.
As far as I recall, they were all connected to the positive and negative terminals (for voltage measurement), and the small connector was used for that purpose.
Schmierpfote Schrauber
Joined: 07/31/2016 Posts: 93 Karma: +21 / -0 Location: Erfurt
24-12-2017, 19:27 Subject: Hello to everyone in the forum, and wishing you all a Merry Christmas |
I stumbled upon an article about the battery connector. Apparently, disconnecting the connector disables the start-stop system. This results in error messages in the instrument cluster, but so far I haven't experienced any problems. Best regards, Wolfgang.
Profile PM Email |
marco257
Joined: 10/09/2013 Posts: 5 Karma: +0 / -0 Location: Klötze 1991 Volkswagen Jetta Premium Support
28-12-2017, 22:01 Subject: Plug next to battery terminals - function? |
klahaui wrote: | Evening,
I would argue that this | also falls under battery management.
That's correct!
Greetings from WOB.
Profile PM Garage |
vfralex1977
Joined: 01/28/2007 Posts: 3 Karma: +0 / -0 Location: 35641
27-02-2022, 17:42 Subject: Plug next to battery terminals - function? |
I'm just chiming in here because this seems like the most appropriate place.
I'm having some problems with my Skoda Kodiaq, especially during the winter months.
The charging capacity may not always be sufficient when using the auxiliary heater.
As a result, it may happen that the vehicle will not start in the morning.
Thanks to the battery management system, vehicle batteries are now only charged to approximately 70%.
"There's no room for improvement because it likely needs to be 'space for recuperative charging'."
This is also relevant for exhaust emissions, especially during inspections and vehicle technical inspections (MOT).
Speak:
I don't just want to pull the plug.
Question:
Is it possible to increase the value, for example, to 90%, and thus activate the LIMA earlier?
vag-driver Profi-Schrauber
28-02-2022, 14:26 Subject: Plug next to battery terminals - function? |
Generally speaking, it's not advisable to stick to an old topic, because you won't be perceived as interesting or innovative.
When it comes to vehicles with auxiliary heating systems, it's important to remember the golden rule: the driving time should be at least equal to the operating time of the auxiliary heater when the engine is off. Whenever possible, it's advisable to recharge more frequently during the winter months.
I am not aware of any legal ways to increase the charging capacity.
Andreas
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1506 Karma: +641 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
02-03-2022, 10:46 Subject: Plug next to battery terminals - function? |
Auxiliary heaters should ideally be operated using a secondary battery, if that is possible in that type of vehicle.
Otherwise, the rule regarding the runtime of the auxiliary heater in relation to driving time always applies, as mentioned before.
Profile PM Garage |
02-03-2022, 14:10 Subject: Plug next to battery terminals - function? |
Rüdi wrote: | Auxiliary heaters should be operated using a secondary battery if it is possible in that type of vehicle....
It likely won't work on most vehicles, and in my opinion, it's not necessary if you use the standing wave frequency (StHz) appropriately.
Andreas
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7786 Karma: +1076 / -0 Location: BAR
02-03-2022, 15:08 Subject: Plug next to battery terminals - function? |
Rüdi wrote: | | Auxiliary heaters should ideally be operated using a secondary battery, if that is at all possible in such vehicles... | It always depends on the intended use of the vehicle. Our operational vehicles still have the secondary battery for the auxiliary heater, office equipment, and communication and operational equipment (digital radio, emergency lights, etc.). If you regularly use your vehicle for sleeping, whether as a camper or an angler, you should take similar precautions.
Does a classic battery disconnect relay still suffice today, or is an additional control unit now also required?
Joined: 04/12/2002 Posts: 18003 Karma: +784 / -0 Location: St.Gallen 2018 Volkswagen T6
02-03-2022, 23:09 Subject: Plug next to battery terminals - function? |
Quote: | | Does a classic battery disconnect relay still suffice today, or does it now also require an additional "brain"? |
Good question, I can't find a built-in battery charger in my T6.
Profile PM WWW Garage |
03-03-2022, 9:15 Subject: Plug next to battery terminals - function? |
vag-driver wrote: |
It won't work on most vehicles, and in my opinion, it's not necessary if you handle the idle speed properly. |
The concept of "meaningful" is relative; the auxiliary heater isn't just intended for pre-heating in the morning, but is often needed for other reasons during longer waiting periods.
Profile PM Garage |
Hutfahrer Schrauber
03-03-2022, 10:53 Subject: Plug next to battery terminals - function? |
It always depends!  There are heaters that heat the water circulation system, which also warms the engine. And there are also air-only heaters.
A friend of mine, who's also an angler, has a built-in air heater in his T5.2, located near the rear right wheel arch, and it already came with a secondary battery installed.
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2549 Karma: +575 / -0 Location: bei Zwickau
03-03-2022, 20:29 Subject: Plug next to battery terminals - function? |
Hello!
My company car is a VW-T6 work vehicle.
It only has one battery.
The auxiliary heater uses the coolant, and I use it every day in the winter. Sometimes even multiple times a day. I haven't had any problems with it, or with the battery, even though the car is now 5.5 years old. I usually drive between 50 and 200 kilometers per day.
The car also has a start-stop system.
I find them annoying, and even dangerous, because it has happened to me several times that I've ended up partially inside a roundabout when entering it. In that phase where you're just rolling, almost coming to a complete stop. Not entirely harmless.
Quite a few people have whistled at me and flipped me off.
I can turn off the start-stop function, but I have to do it again every time I start the engine. But I sometimes forget that.
If I could disable it with that,
That wouldn't be bad.
