Three faulty control units within one year
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
servusssss
Post20-05-2022, 7:35    Subject: Three faulty control units within one year Quote
Hello everyone,
I have had three control units fail on my Sharan in the last 12 months.
It all started with the "radio".
Address 5F: Information selection. I (J794) Label file: | 5G0-035-MIB-STD2.clb
Part number SW: 5C0 035 680 B HW: 5C0 035 680 B
This week, the all-wheel drive control unit failed.
Address 22: All-wheel drive (J492) Label file: * DRV\0CQ-907-554.clb
Part number SW: 0AY 907 554 J Hardware number: 0CQ 525 130
To top it all off:
Address 16: Steering wheel electronics (J527)
Label file: | DRV\5K0-953-569.clb
Part number SW: 5K0 953 501 ED, HW: 5K0 953 569 AN.
Component: STEERING MODULE 016 0180
Revision: FF010042 Serial number: 20151016101444
Encoding: 3102C40008
Operating Number: WSC 00020 999 00000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 70EA7552ABCEB109B5-8025
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 6C0 959 442 B, HW: 6C0 959 442 B, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-TAT H04 0019
Serial number: 2521505130500497AF2B
Encoding: 2C0000
2 error codes found:
448019 - Multifunction buttons on the steering wheel, left side.
B114B 96 [009] - Internal component failure.
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 3.
Error frequency: 1
Lost Count: 117
Mileage: 99431 km
Date: 2022.05.19
Time: 20:57:21
448275 - Multifunction steering wheel controls on the right-hand side.
B114C 96 [009] - Internal component error.
Error priority: 3.
Error frequency: 1
Lost Count: 117
Mileage: 99431 km
Date: 2022.05.19
Time: 20:57:21
The last errors cannot be deleted, so they are also in the trash.
Okay, now to my question: Could there be a deeper problem here? Is it related to the power supply? Does it measure 14.7V when the engine is running?
Does anyone know about these engine control units (ECUs) failing?
SG Christian.
Translated on 09-07-2026, 6:18.
Post20-05-2022, 7:43    Subject: Three faulty control units within one year Quote
Hi Christian,
I'm not familiar with that. The question is, is the cause a voltage surge in the vehicle's electrical system, or a water/moisture problem?
The latter should be relatively easy to determine.
If you have a HEX-NET device, you could relatively easily log the on-board voltage while driving.
Or just use a laptop.
Possible causes include chafed cables in the tree that intermittently cause short circuits, and voltage spikes in the vehicle's electrical system when the short circuit is resolved.
You should also consider whether anything has been modified in the radio, as the pin configuration of the ISO connector is not standardized, and it's conceivable that, unintentionally, a speaker output could be connected to the CAN or K-line...
Translated on 09-07-2026, 6:24.
Post23-06-2022, 15:37    Subject: Three faulty control units within one year Quote
Has anything emerged regarding the cause of the electronic control unit (ECU) failures?
Translated on 09-07-2026, 6:25.
No new posts EDC15 Steuergeräte, Software updatefähig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Einstellung der EinspritzdĂźsen/DĂźsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Problem innerhalb des Gehäuses einer VP37 Diesel Engine Technology
No new posts Timing Belt Failure: VW Golf V - Twice in 2 Years? Diesel Engine Technology
No new posts defekte VTG-Laderdose Diesel Engine Technology
No new posts Defective Diesel Pump: What to Do Now? Diesel Engine Technology
